Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 12-04-2006, 10:04 AM   #1
DebianDog
Default Understanding Throttle and Pitch Curves 101
Bob uses a few radios and paper to make this an easy concept
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 01-24-2007, 07:14 PM   #2
EDWARD1013
DO THEY HAVE A MANUAL FOR HOW TO SET UP THE PITCH (WITH PICTURES) SO I CAN DO THE FINAL SET UP?
THANK YOU, MAC MCWILLIAMS
EDWARD1013 is offline        Reply With Quote
Old 01-25-2007, 06:16 AM   #3
Jermo
Mac, Refer to the Finless video's, the CCPM1 and CCPM2 videos have the final setup I believe.
Jermo
Jerry Moore, AMA #878954, IRCHA #2988
Pantera .61bbc - Takes a licking and keeps on kicking! , Trex 500CF, MCPX V2 Readyheli BL
Ok, you can fly...but can you HOVER??
KISS = Keep it simple stupid (to maximize fun and reduce costs!)
Jermo is online now        Reply With Quote
Old 09-08-2009, 11:15 PM   #4
Boomer2282
hello i just finished puting together a trex 250 and flying it today i noticed that is drifting to the left alot but i checked and double checked my servos and they are all straight i also checked my settings on my radio (spektrum dx6i) and it seems fine so i was wondering if you have some advice i can use. of course if you have the time thank you so very much in advance have a great day..
Boomer2282 is offline        Reply With Quote
Old 09-09-2009, 06:41 AM   #5
Dusty1000
Hi, what you describe is normal, helis drift to the left when the swash plate is level, because as the main rotor 'pulls' the heli directly up, the tail rotor blows it to the left. Some people trim the swashplate to a slight angle to compensate for this, others recommend you leave it as it is and get used to it since when you fly inverted you'll want the swashplate to be level anyway.
Also the smaller the heli is, the more you notice it drifting to the left.
HTH
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
Old 09-15-2009, 06:47 PM   #6
Kasey1
HTH
Dusty
ahhhhhhhhhhhh,is reallly??????????
thanks for the informations bro..
Kasey1 is offline        Reply With Quote
Old 09-15-2009, 06:50 PM   #7
Kasey1
Jermo
Ahhhhhhhhhhhh,I just think so
Old 09-19-2009, 12:52 PM   #8
TaraFirma
It's called translating tendency. The TR counteracts MR Torque and pushes the heli opposite ot tial rotor thrust (to the left in a clockwise rotating MR heli)
TaraFirma is offline        Reply With Quote
Old 01-13-2010, 09:07 PM   #9
46uu
VERY informative video. Have read much about this but this is the first time I really understand.
46uu is offline        Reply With Quote
Old 01-24-2010, 08:26 PM   #10
Aerobat1
Awesome video. Finally someone that can explain in understandable language. Thanks!!!!!!!!!!!!!!
Aerobat1 is offline        Reply With Quote
Old 01-28-2010, 06:20 AM   #11
weblogix01
This is really tough to understand but its a good information thanks..
weblogix01 is offline        Reply With Quote
Old 02-09-2010, 01:06 PM   #12
joecec
SWEET! I Love this stuff
joecec is offline        Reply With Quote
Old 02-22-2010, 08:36 AM   #13
Sidewinder1
Many, many thanks; unfortunately (for wifey) I'll need a need radio, now that I understand the relationship between throttle and pitch curves.
Side
Sidewinder1 is offline        Reply With Quote
Old 06-13-2010, 03:03 AM   #14
Mazin
Your the man, as a newb i thought I had an Idea but have learned so much from this video and 401 101 I just have to give a huge THX!!!! and you da man!!!!
Mazin is offline        Reply With Quote
Old 09-03-2010, 12:54 PM   #15
Rc_Collector
Thanks so much for this video, I´m newbie and finally understand how to set the curves. Very helpfull !!!!!
Rc_Collector is offline        Reply With Quote
Old 11-23-2010, 10:53 PM   #16
dustyjoe
Buddy Where do I find these videos. I need to check them out also.
dustyjoe is offline        Reply With Quote
Old 12-05-2010, 11:33 PM   #17
slamdance
Two words. HELIFREAKS VIDEOS. If not for finless bob and his detailed videos on trex450 and trex500, I wouldn't be able to have "perfect(no trim)" setup for my heli's.
If you are a former planker who's gotten away with non-computer tx, you are in rcheli technology now. No more shortcuts. YOU MUST ABSOLUTELY, learn everything about the tx servo/setup for the heli. If not, find a "mentor" on the field to do it for you. However, be warned he won't always be around after you crash/repair your heli.
It's to your advantage to watch the video so that you can FULLY MASTER the set-up process. Finless Bob has made great detailed videos. Even showing exactly what buttons to press on JR/Spektrum/Futaba transmitters. It will pay off in the future when you can fine tune the pitch/throttle curve yourself, so that heli flys even better.
slamdance is offline        Reply With Quote
Old 02-15-2011, 09:31 PM   #18
N3SQV
Originally Posted by DebianDog View Post
Does anyone have a link to this video in a different format? youtube perhaps? My computer will not play it. Says no plugin for asf available
Blade MCX2; MSR; Spektrum DX7
N3SQV is offline        Reply With Quote
Old 02-15-2011, 11:22 PM   #19
SD_GH124156
VLC Player, will play everything and it's opensource..
http://www.videolan.org/vlc/
SD_GH124156 is online now        Reply With Quote
Old 02-16-2011, 07:20 AM   #20
N3SQV
Thanks for the link. Soon as I get a hard drive installed I'll download that. I'm running off a 4 gig thumb drive right now
