Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 07-29-2010, 10:43 AM   #1
syn90
Default Can I use 95mm tail blades with 520mm mains???
I have some spare 95 mm tail blades from my 600. Can I use these on the 550 if I stick to the 520 mm main blades?
syn90 is offline        Reply With Quote
Old 07-29-2010, 02:32 PM   #2
philipfrank
yes
philipfrank is offline        Reply With Quote
Old 07-30-2010, 04:21 PM   #3
spike5150
You can, but I think you are going the wrong direction. better to go smaller. You may have trouble getting your gyro gain set as the tail is going to have a lot of authority.
spike5150 is offline        Reply With Quote
Old 07-30-2010, 04:27 PM   #4
philipfrank
longer baldes require less gain and give more tail authority.
it's a good thing. (less wear on servo with lower gain)
Old 07-30-2010, 05:56 PM   #5
mss001
Longer blades also result in higher mechanical gain (same as moving the ball on the servo horn out), which means less resolution in the tail movements (which could lead to wag in extreme cases).
Michael
Trex 450 sport
Radikal G30 - Hanson G26 3D max
mss001 is offline        Reply With Quote
Old 07-30-2010, 06:19 PM   #6
philipfrank
never had a problem and have always preferred to run longer blades.
everyone at our field has the same preference.
Old 07-30-2010, 08:31 PM   #7
syn90
cool, thanks for all the replies guys. I'll start with the stock ones and experiment a little after I get it up and running and work out any initial maiden issues before I introduce the larger tail blades.
