Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 12-04-2006, 10:11 AM   #1
DebianDog
Default Blade Tracking 101
You do know how to track your blade correctly... right?
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 01-10-2007, 12:34 PM   #2
wilesrevo
im like everone else in the world i dont know what im doing and i dotn really have no one to help me i managed to crash my mx400 before it got off the ground the blades are not tracking and i dont no how to fix it
wilesrevo is offline        Reply With Quote
Old 01-10-2007, 12:38 PM   #3
DebianDog
You should be able to look at your helicopter in a hover and see one blade. How does you heli compare to the one in the video?
Old 01-10-2007, 02:36 PM   #4
ClayK
I think it's hard for a first time pilot to track blades up in the air. Hovering can be difficult at first and trying to hold it in place while trying to track it can be daunting. I suggest either having someone hover the helicopter for you or having someone watch the blade track while you hold it in a hover, at least until you are comfortable.
Veni, Vidi, Velcro
I came, I saw, I stuck around
Bringing people out of Radio Shack and into the hobby.
μολὼν λαβέ
ΜΟΛΩΝ ΛΑΒΕ
ClayK is offline        Reply With Quote
Old 06-26-2007, 02:11 AM   #5
halfassastronaught
no kidding, but i have my wife hold my heli down on the bar while i throttle up and eye ball them against a white wall......hey, shes insured.
you cant soar with eagles if your pecking with chickens.
halfassastronaught is offline        Reply With Quote
Old 10-03-2007, 03:27 PM   #6
istandalone
before i could hover steadily i just did it on the ground. spooled it up to just before it gets light on the skids, and then look. so far, doing it like that hasn't caused problems, but now that i've nailed tail in hovering i do it the "right" way.
AMA# 906249
i'm now down to one heli (align sev2) but have an arsenal of 120+ mph jets. hmm...i think i see a pattern here lol.
istandalone is offline        Reply With Quote
Old 10-13-2007, 07:27 PM   #7
Rick Rotorhead
For my lil' T450 I take the less technical approach. Hover it, if the tracking is out, land and do one turn on ONE of the the short links to the blade grips, noting which one I've turned. Hover again if its ok, then fine, if its twice as bad then land and wind the same short link two turns the other way and do a test hover again. That normally fixes it.
450SE Silver - Power: Neu1107-2Y + 10t pinion ESC: Jazz 40-6-18 Governed. - Batts: 4s, FP 2100 Evolites. Pitch +/- 12* (TC63 PC 0,25,50,75,100), cyclic 6* HS2900
HS65Mg x3 + GY401 + S9650 tail.... Rx: AR6200 - Tx: FF9Super(T9CP) +Spektrum Module
Crash count = 13 for 179. Trex time aloft = 22:42
Rick Rotorhead is offline        Reply With Quote
Old 11-30-2007, 04:18 PM   #8
mattkreps
I just put it under the pitch gage and get it perfect before i ever take it off
Trex 450SE V2, Trex 500 CF, Trex 600 Nitro Pro
DX7, AR7000s, JR770s
2.4 is for people who only listen to AM radio (like me)
mattkreps is offline        Reply With Quote
Old 12-01-2007, 08:54 PM   #9
Rick Rotorhead
With the T450, just getting the blades staticly perfect in pitch doesn't guarrantee perfect tracking I'm afraid. you have to see 'em in flight really.
Old 12-01-2007, 09:57 PM   #10
steffgiguere
You know what I use my pitch gauge and set them as straight as possible at mid stick to 0 pitch and most of the time tracking is perfect.
steffgiguere is offline        Reply With Quote
Old 05-31-2008, 09:14 AM   #11
Derrell
Hi Everyone,
Newbie here...I got a strange situation....after watching Bob Whites Vid on blade balancing I went to try it, Both of my blades (woodies for a HBK2) weigh the same but when I go to balance them I have to add 1g of tape to get it to balance. What do I need to do? Is the different weighted balancing tape?The clear tape was wrapped almost four times around the blade and IMO that seems way to much. Any help would be great.
Derrell is offline        Reply With Quote
Old 06-04-2008, 07:14 PM   #12
Seledtsov
Hi, Derrell!
4 times are not so much for HBK2 woodies really.
Seledtsov is offline        Reply With Quote
Old 07-19-2008, 08:35 PM   #13
69daytona
Default Tape and Blade balance
Has anyone used Golf Lead Tape instead of 2-8 wraps of Vinyl tape? I have about a 50 foot by 1/2 inch roll someplace around. If used, where would it be placed, 1 in. from end, middle, top, bottom or leading edge of the blade? Use to use it to help balance the wheels on my 1/4 and 1/5 scale RC cars.
69daytona is offline        Reply With Quote
Old 07-20-2008, 10:32 PM   #14
mattkreps
Originally Posted by Derrell View Post
Hi Everyone,
that just means the cg on the blades is off. on a 450 this dose not need to be perfect
Old 08-10-2008, 04:21 PM   #15
RappyChappy
Hi Everyone,
I had blades that were way out of balance that came with my Raptor kit. I took the blades back to the shop and told the guy. He checked them over and said they were so bad, they were unsafe and changed them for me.
RappyChappy is offline        Reply With Quote
Old 10-21-2008, 12:08 AM   #16
stormtrooper
Default Blade Tracking on BELT CP and the Pitch Guage
I'm rather confused...
I setup the pitch on both blades at 0 degrees mid-stick. Spooled the heli and tracking is bad. So, I turn the pitch control of the higher blade to make it go down. Test, then turn again until it tracks or almost tracks. However, when it does track, it turns out the pitch angle of the blade I adjusted is off about -2 degrees already or so at mid-stick!
To me, it would mean that both blades aren't angled the same and would affect flight, right?
stormtrooper is offline        Reply With Quote
Old 10-22-2008, 05:44 PM   #17
Pinecone
It would, IF both blades were EXACTLY the same. Might be a difference in the airfoil shape, leading edge shape, one blade might have a twist in it, it might be warped to add camber. Lots of reasons that the measured pitch would not be equal to get them to track.
But when they are tracking properly, you are at equal EFFECTIVE pitch, which is what we really want.
BTW, what blades? If they are the yellow/black Align "Carbon" blades, you will find the tracking changes from day to day and flight to flight. Do yourself a favor and toss them out.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 01-28-2009, 05:52 PM   #18
squirrel4207
Question UMM Tracking?
what exactly is tracking, how do you do it and why?
squirrel4207 is offline        Reply With Quote
Old 01-29-2009, 02:36 PM   #19
Rollin_3z
Tracks as in railroad tracks, you want de train to follow de tracks..no?
Rollin_3z is offline        Reply With Quote
Old 03-27-2009, 01:09 PM   #20
mtnbike101
For a beginner, could you recommend a couple of good brands\models of blades...maybe both a wood and carbon suggestion? I had initially put the aforementioned blades on my list due to them being "carbon" and the low price, but your input has changed my mind. FYI, they will be going on a Furion 450 if that makes a difference.
Thanks,
Jeff
mtnbike101 is offline        Reply With Quote
