Old 07-30-2010, 10:55 PM   #1
crazymikey555
Default learning the hard way
So today i had a little bit of light left after work. So i rushed to get the blade out looked it over real quick will never make the mistake again got up around 40 feet in the air and before i knew it. it was spinning in circles well i tried my hardest to bring it down easy didn't work so well smashed hard into the ground. so i looked at the damage and sre enough the belt was loose i learn on thing from this always do a good preflight look over.
crazymikey555 is offline        Reply With Quote
Old 07-31-2010, 12:47 AM   #2
mtymyk
words to live by!!!!! and they'll save you lots of money lol!
Logo600, 7HV, Goblin700, Goblin770 14s, Goblin 500
Vbar, Kontronik, JR, Scorpion
Team Rotorquest
mtymyk is offline        Reply With Quote
Old 07-31-2010, 05:10 AM   #3
Wiggen
Did you hit throttle hold when this happened?This is always the right thing to do when the heli spins out of control like that.The heli will stop spinning and you can auto her to the ground.Even if your not good at auto,s the crash damage will be a lot less.
Wiggen is offline        Reply With Quote
Old 07-31-2010, 07:07 AM   #4
dazzzer30
yer but the belt might have came loose when you was in the air not on the ground but i know what you mean about checking everything over good. sometimes the last things you would think of checking become the big problems .
dazzzer30 is offline        Reply With Quote
Old 07-31-2010, 07:28 AM   #5
Encoder
Yeah my last time out I flew 3 packs and on the forth about 3 minutes into the flight she started making a strange chirping sound. Decided to land her and turned out the belt stretched a bit. Tightened up and good to go. But I'll check her over before flight and listen for the telltale chirping sound which I can only imagine is the belt slapping the inside of the tail boom.
Blade 400, DS35000G,GY520, DS287MGs on cyclic, CC BEC
Blade MSR
Blade MCX
Encoder is offline        Reply With Quote
Old 08-01-2010, 06:27 AM   #6
Guzziman
You know if you had of checked before flight.That you would have the answer as to if was loose before you started.Or if it cames loose in flight.
Preflight check all the time.
MAAA membership AUS71789
B400 gy401 s9257 tail servo
HS 65 mg servos this thing rocks
Guzziman is offline        Reply With Quote
Old 08-01-2010, 08:42 AM   #7
Encoder
Very true.
Blade MSR
Blade MCX
