Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Kyosho
Kyosho Kyosho Caliber, Kyosho Helicopters
Old 12-06-2006, 05:55 AM   #1
shaun.kendall
Default Setting Pitch on a Cal5
I know, I know, I should find a pilot to help me. However, until that day, what is the correct way to set pitch on the Cal5? Is it set on the radio via the limiting of the movement of the swash? I ask because that is how I did it. I do not have a full range of up down motion, but with the pitch gauge on I have -2 at the low end, 5.5 at midpoint and 8 at the top. yeah, I am just starting out.
However, I have noticed people with other helis talking about adjusting control arms to set pitch. Is the way I did it pathetically wrong? It flies, and hovers as it is, however, I do not want to set myself up for big trouble down the road.
Look Ma! I can hover!
shaun.kendall is offline        Reply With Quote
Old 12-06-2006, 08:48 AM   #2
Laurens
What you want is mechanically zero pitch at midstick. This means adjusting the rods. After you set the pitch mechanically you can limit the maximum and minimum pitch with your Tx.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 12-07-2006, 12:55 PM   #3
kraaijer
Mind you that when setting 0 degrees mid-stick it is suggested that you are in idle-up (aerobatics mode if you like).
Ron
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-)
kraaijer is offline        Reply With Quote
Old 12-07-2006, 10:07 PM   #4
shaun.kendall
I see. Thank you. I will go out and do that right now.
Old 06-24-2007, 06:23 PM   #5
shesha
If yuo have a radio with a monitor on the stick to know where things are like the Jr PCM9X one and or 2 then that would be spot on. avoid using the pitch curve screen to kno where center stick is, i had a full 1 degree of when usingg the pitch curve screen then the monitor screen.
shesha is offline        Reply With Quote
