Go Back   HeliFreak > R/C Helicopter Support > Kasama Helicopters and Upgrades
Kasama Helicopters and Upgrades Kasama Srimok 90 Helicopters and Upgrades Discussion
Old 08-03-2010, 08:14 PM   #1
billiano
Default Power problems ?
Hi to all of you.
My set up is 3 JR DS8917 HV an Align DS610 for throttle and a JR DS8900 for tail.
I also use a FBL gyro from Germany AC-3X a Spectrum 2.4G AR-9000 RX(or advise me to replace with JR 921 9CH 2.4G RX) a Scott Gray Reactor-X regulator and
a Thunder Power 2S2P 5300Mah 7.4V RX battery and finally an Aerospire MultiGov.
My heli is being repaired at this moment but as I was flying at 9ft high I switched to Idle2.
The heli reacted like crazy and screwed into ground as if I had minus pitch.
Just for the story my fail safe preset is the same as Normal in low stick position which means -4 pitch and throttle hold.
What is your opinion....
Is it entered failsafe mode due to vibration or it was a fade out due to power drain?
Finally what do you think of plugging a second battery in the RX just an old 4.8V NiMH battery to be my alternative?
And last but not least is it possible that Reactor-X was reset due to overheat or over-current?
Bill
P.S: I got from Mr Kasama the updated part for Swashplate drive arm
it's KSM10-H10 (new) and KSM10-90H05(old)
EVERY HELP IS WELCOME....
Bill
Esprit Model Flying, TDR Rigid x2
F9 Fiberglass Europe Canopies
billiano is offline        Reply With Quote
Old 08-03-2010, 11:18 PM   #2
chasers
How do you go about getting the updated parts from Kasama? Do we email him or??
chasers is offline        Reply With Quote
Old 08-04-2010, 03:52 AM   #3
Vetequk
Email him with the serial number of you model & he will reply.
Vetequk is offline        Reply With Quote
Old 08-04-2010, 03:56 AM   #4
billiano
I got the update part by chance .I asked for the swashplate drive arms set like the one on every picture but he sent me the updated one.
Bill
Old 08-04-2010, 05:42 AM   #5
Mercuriell
POsts moved out of Technical Tips sticky !
I think your problem is not power supply related - the fact that it happened just when you switched to idle2 suggests that your pitch curve was different at that throttle stich position - maybe a linear curve whereas you have less negative in normal mode - if your heli is still functional try flicking conditions and seeing if pitch changes - otherwise check out you pitch curves
John
Mercuriell is online now        Reply With Quote
Old 08-04-2010, 10:00 AM   #6
billiano
John how are you?
I believe it has to do with gyro vibration for that reason I will place the updated gyro
plate mount KSM10-F29 .
And may god be with us.because the gyro unit its light.
Or during changing to ID 2 I moved my stick just below middle and the heli crashed but I still cannot believe that.,it doesn't seems correct.
Anyway I was thinking of getting also from JR that little machine that shows fade outs & frames lost of signal.
Although its been said a few times John what are your headspeeds?
Thanx Bill
Bill
Old 08-05-2010, 03:54 AM   #7
Mercuriell
HI Bill - let us know how you go !!! I run 1950 and 2050 on the Faifa and 1850 and 1950 on the nitro
John
Old 08-05-2010, 05:02 AM   #8
billiano
During my last flight I had 1750 and 1850.
But now I will try to balance the moving parts one more tie better
Bill
Old 09-08-2010, 07:06 PM   #9
billiano
Hi to all of you ...
Firstly I had increased vibes because of my stupidity and placing the piston mark of my YS-91 SR at 2o'clock while the correct is at 7 o'clock.(Influenced by my OSMAXs)
After some searching I found the correct way.
I trimmed my new frames in the tank area and finally I had my gears mess very smooth.
And last I got my Kasama Gyro Mount.
Now I have no vibes at all.
I set the heli up without fuel mix and gov RPM.(Multigov)
I did some flights and its quite like a typewriter.
Temps are correct and now in the next flight I will set also the Gov.
The heli even without the Gov has a lot of power.
I hope that I will love my heli all the way from the beginning.
Bill
Old 09-12-2010, 07:03 PM   #10
billiano
I did some setting on my MultiGov at 1800 IDL1 and 1900 IDL2.
The heli is awesome.
Now the only thing I have to do it's to improve my moves.
Bill
