Old 08-09-2010, 11:02 AM   #1
Woody_99
Default Counter Clockwise Piro Rate
Heli piros clockwise just fine, but is a little slow the other way. I'd like to match them up a little closer.
I think I've read that to increase the piro rate, that I would adjust the rudder end point, right?
Thanks.
Woody_99 is offline        Reply With Quote
Old 08-09-2010, 11:19 AM   #2
whoanelly
This is pretty normal but what u can do is go into you travel adjust under rudder,,increase the values..remember on the dx6 u have to move the stick so u can adjust in both directions,,becarefull cause 125 is max and she will spin like a top. So try increase one side more than other. Hope that helps u out.
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
