Old 08-09-2010, 06:15 PM   #1
dazzzer30
Default washout mixing arms?
one of my washout base mixing arms look a little higher than the other one will this effect anything ?
dazzzer30 is offline        Reply With Quote
Old 08-09-2010, 06:43 PM   #2
pril250
On a perfectly set head all (Swash, Washout, Cage, Paddles and Blades) should be perfectly level at mid stick with a linear pitch curve and no trims.
Blade400
pril250 is offline        Reply With Quote
Old 08-09-2010, 06:59 PM   #3
dazzzer30
says in the manual that they should be the same lengh always, but at mid stick one looks a little higher, i guess i could turn the one that is a little higher and see if its more level but i didnt want to do that .
Old 08-10-2010, 05:23 AM   #4
TonyG23
You mentioned in a previous post that your swash was not level. Sounds like to me that your servo`s and head are out. As I suggested in your other post take a look at Sokals vids on head set up.
Rip the head down and start again from the bottom and work your way up. As the other poster said everything should be level at mid stick
TonyG23 is offline        Reply With Quote
