Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Ufly
Ufly Walkera Ufly Helicopter Support
Old 08-10-2010, 01:06 PM   #1
bassangler43
Default Can someone tell me the length of stock UFLY blades?
The reason I ask... I just did a complete brushless upgrade for my CB180D and went with the exended blades from RTF-HELI. They have no name or part number on any. I happened to notice the UFLY blades are almost identical but I need the length to be sure that's what they are. What I'm using now is right at 9 inches long. I'm just looking for a cheaper alternative as opposed to the blades from RTF. Any help will be appreciated. Thanks!!!
Chris
bassangler43 is offline        Reply With Quote
Old 08-11-2010, 03:38 AM   #2
ting
The stock UFLYS balde is 240 mm (9 3/8 inches).
Ting.
ting is offline        Reply With Quote
Old 08-11-2010, 03:59 AM   #3
bassangler43
Default Thanks
Ting,
Thanks for taking the time to respond.
Best Regards,
Chris
Old 01-02-2011, 11:24 AM   #4
graffin639
Hi
talking about blades...is there an option like the Airy Hardened Blades I got for my little Lama V4? they are unbreakable! and for the hard times I am having with this helicopter i need hard blades
thanks
graffin639 is offline        Reply With Quote
Old 02-24-2011, 03:29 AM   #5
magicmarty
get some of the extreme fiberglass reinforced blades for the honey bee v2 they are the same size and are a lot stronger then the stock ufly blades...boomtownhobbies.com has them for $8.50 a set plus ship...a guy told me he has crashed into his car, house, and hit a wood rail road tie and didn't break the extreme blades ..in fact he said one of the blades was stuck in the wood and he had to pry it out......i have a set coming in a couple of days , i also just installed a set of the superblades xp on my uflys ..they seem better then the stock but i had to modify them to get them to fit between the blade grips..the mounting ring on them is near 4mm thick i had to shave it down to 2mm to fit the ufly blade grips...the extreme blades will fit without any modification to them...
magicmarty is offline        Reply With Quote
Old 04-28-2011, 11:01 PM   #6
arquitron
Ting.
And the blade root thickness? Thx
Gazaur MARS 480 * TT Mini Titan E325 SE * Walkera UFLYS/CB180Z-Pro/CB100
arquitron is offline        Reply With Quote
Old 04-29-2011, 06:42 AM   #7
magicmarty
the stock blade mounting ring at the root is 2mm ....
