Old 02-26-2016, 05:39 PM   #2241
nightflyr
Originally Posted by franknsled View Post
Not to rain on your parade nightflyr, but you need some padlocks on those pins if you want to know where that spare is all the time.
To be honest...
It would be easier to try to unbolt the tire than pull the receivers..
The alarm system has a mic located at the tow bar mount....
Just pulling a pin (which isn't too easy, you have to jiggle the carrier) will set it off.
I know, I tried it already.
Besides.. In its original location it's quite easy to just lower the spare and pull it from under the rear.
nightflyr is online now        Reply With Quote
Old 02-27-2016, 06:04 AM   #2242
LowTek
My solution to a similar need was a section of plywood and some risers to make a false floor inside the back of my Cherokee. Gave up about 10 inches of height + had space to put in a storage bin next to the tire. I hinged the shelf about 2/3rd back for easy access to tire an storage.
LowTek is offline        Reply With Quote
Old 02-27-2016, 08:53 AM   #2243
nightflyr
Nice idea
In order to make that work for me, I'd need to drop my rear seats.
My tire would pretty much fill the rear cargo area with the seats in place.
Old 04-21-2016, 03:43 AM   #2244
kokorun
Hellow Everrybody
https://www.google.co.th/
kokorun is offline        Reply With Quote
