| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I am about to purchase a new balancer. Which one do you think is better to be used with an Astro 109?
It's easy to find an excuse to do wrong. Hard is not to find an excuse to do right. |
I would go with the V-Balance Module. They are working great with the 109's.
William James To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. If you fly you are going to crash. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Another vote for the V Balancer, it can shut off the Astro 109 if cells go over-voltage making it a very safe setup for fast charging as well, for charges on the field I charge my FP 4900 packs at 8A, at this level it takes around 30 minutes to fully charge a pack.
Steve H Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG |
The LBA10Net also does those things, but you'd probably have to make your own adapters for FP/TP 6S packs. So far, I haven't found anybody that makes one for sale. The V-Balancer would be an off the shelf solution, so that may be better.
Trooper Sam -Planks are like feel-good buddy movies, and helis are like horror movies. You just gotta like being scared. |
i'm using the v balance, and am really liking it.
Make it go BOOM Team Flightpower |
#6 |
One advantage of the LBA10 is its ability to be ganged up so that you can charge 12S as a single unit. You'll just have to make your own adapter to go with the TP/FP balance plug. LBA10 will also shut off your charger if one cell gets above 4.2V, thereby making it idiot proof.
**If you ain't crashing, you're not flying hard enough** |
#7 |
Hi all,
I'm in the same quandry; lba10 or v balance. will the either 'trip' off when the astro109 goes into it's final mode of charging, pulsing the voltage? Cheers, Leslie
If you can't stand behind our troops, please feel free to stand in front of them. |
#8 |
I'm running the LBA-10 with great results with the Astro 109.
Jay Mowl |
#9 |
Thanks guys. Appreciated.
I think I am set!
#10 |
It doesn't trip unless you've got massive imbalance. I've rigged mine so I can charge my 3S x 2 packs simultaneously as 6S. The only time it trips is with my mixed packs (PQ 3700 and Maxamps 4000), and I know I have a bad cell on the PQ. When it trips like that, I just lower the charge rate, and the ballancer has enough time to compensate for the imbalance.
#11 |
I just got a reply from Bishop Power Products, and they'll make a custom adapter for the LBA10 for $8.95.
#12 |
Hi all,
Thanks Bonedoc! Which balancer are you refering to? Cheers, Leslie
#13 |
LBA10
#14 |
I have both - my V-Balance works really well and my Hyperion LBA10 6S doesn't kick start my 109 charger - so I'd go with the VB
John |
#15 | |
#16 | ||
John |
#17 |
DOH, you need to push the mode again to start it
#18 | |
John |
#19 | ||
#20 |
can someone confirm if the 2 lba10's can be networked to charge a 10S or 12S battery or if they will just charge 2 6S batteries together. I have seen all the literature and no where have I seen it say it will charge a 10S or 12S battery. All it says is that it will charge 2 of the same type batteries together essentially letting you charge two batteries on one charger. This and the hyperion charger look like a very good opportunity if they work.
Also, what is max amp rate? Can the LBA10 handle 10 amps going through it if I decide I want to charge a 5000mah pack at 2C? |
