Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 08-17-2010, 04:05 PM   #1
Mikej
Default Tip for getting 0 degrees pitch
This is an update on a tip that Finless Bob gives in one of his videos - to get 0 degrees on a CNC head stick an appropriate diameter hex-driver between the head block and grip arm, it must be a very good tight fit.
Even works on the plastic heads (different size hex driver)
Name:	P1010391 (Large).jpg
ID:	174626   Click image for larger version
Name:	P1010393 (Large).jpg
ID:	174627   Click image for larger version
Name:	P1010394 (Large).jpg
Mikej is offline        Reply With Quote
Old 08-18-2010, 02:52 AM   #2
Jerrymac
Hey Mike, here is another little tip to "check" for 0 pitch without a gauge.( Sorry, no piccie)
Rotate one main blade 90 degrees in the grip, then rotate the other blade 90 in the opposite direction in the grip. The main blades should be perfectly horizontal from tip to tip. If there is any pitch at all in either blade, they will not be straight across.
I don't need the latest and greatest. I just need more time to fly what I have.
Helipro 450se, Gaui 200, Gaui 425 x 2, Gaui "HeadHunter 500, Gaui 550
Jerrymac is offline        Reply With Quote
Old 08-18-2010, 03:32 AM   #3
Mikej
Yeah - I use that as well - the only challenge is that you sometimes get blade droop
Perhaps this is only with older woodies
Old 08-18-2010, 03:43 AM   #4
Jerrymac
Old 08-18-2010, 07:47 AM   #5
nexgen
That hex wrench method works great. The plastic tail pitch links (forks) also fit perfectly in the seesaw.
I also use Ray Stacys method; hang the heli vertical, and fold the blades back. When they hang parallel to the boom and each other you have 0°. Since the grips/links are not supporting the blades, any head slop will not affect the result.
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is online now        Reply With Quote
