Old 08-17-2010, 07:17 PM   #1
Michaelinpr
Default Installing 3G Link. I got a weird error window.
Here is a pic of what it said. I havent a clue what it means. This happens as soon as I open the program and happens through out the program. I have not yet updated the unit on the heli because of this problem. If I click continue or quit it reappears. I have to click quit many times quickly to quit the program or to continue. If I continue it reappears as soon as I open or change something.
FUSION 50 FBL, Scorp HKIII-4025-550/Scorp V 130,610's, V Bar/650
GAUI XB5-EXTREME 12s
, Scorp HK-4025-550/CC 80HV, 610's, V Bar/650
AleeS RUSH 750-KDE-700XF-395/YGE160HV, RJX FS0521HV's, IKON/RJX FS0521HV
Michaelinpr is online now        Reply With Quote
Old 08-17-2010, 07:34 PM   #2
FrozenOne
I would start by uninstalling and reinstalling the 3G software. If that does not work you can open my computer. Open drive C. Create a Folder named 'My_setting'. Open the 'My_setting' folder. Create a folder named 'ALIGN_sys' inside of the 'My_setting' folder. Run the 3G software and see what happens. You may be prompted for administrator access when creating the folder in the root of drive C.
Odd problem, hopefully the reinstall will fix it.
700N LE - 3G, 91HZ-R, SB-20FH-2, AR7100R, Edge 693FBL
600NSP - 3G, 55HZ, B320, 8717, 8900G, AR7100, Edge 603FBL
450 Pro & 450 SEv2 Stock Setups
450 SEv2 - SK360, MiniG, HKII-2221-6, CC 60, Edge 325FBL
250 SE - GY520, 290G & 250 Orig Stock Setup ---- JR 12x/Spek DX7se
FrozenOne is offline        Reply With Quote
Old 08-17-2010, 07:49 PM   #3
Michaelinpr
I forgot to say that I already tried to reinstall. I am to tired and pissed at the computer to continue tonight. I will try tomorrow.
Thanks FrozenOne
Old 08-17-2010, 11:56 PM   #4
HiroboFreak
Download & install Microsoft .NET Framework 4.
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro
| JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote
Old 08-24-2010, 06:14 PM   #5
Michaelinpr
I have installed what HiroboFreak said and reinstalled the 3G program. I was able to update the sensor and controller with seeing the same window pop up once.
I am still getting the same message in the configuration program for any setting, function, or anything I try to click on or change.
Can someone please help. I really want to tune the heli to my personal flying style.
Will the 3G unit still fly with out doing any of the minor adjustments in the program? I mean can I just use the V2.1 updated unit as I did the original version unit?
Old 08-24-2010, 06:41 PM   #6
Corrari
Have you tryed someone elses pc?
Compass 6HV, TotalG, BLS251, DX7S.
Kasama Srimok, Scorpion HK-4525-520KV, TotalG, BLS251, DX7S.
...and the rest...
Corrari is offline        Reply With Quote
Old 08-24-2010, 07:33 PM   #7
Michaelinpr
Not yet. I havent had access to one but I was thinking to find someone with one to let me try.
Old 08-24-2010, 09:14 PM   #8
Corrari
Was just a thought. Might help you eliminate either your pc or the software.
...and the rest...
Old 08-25-2010, 09:28 AM   #9
vikas
correct me if im wrong but you need 3.5 not 4
KASAMA SRIMOK FAIFA SKOOKUM
TREX450 BEAST X
vikas is offline        Reply With Quote
Old 08-25-2010, 05:19 PM   #10
Michaelinpr
Honestly I dont even really know what the program is. I downloaded and installed the link. If another computer doesnt work, should I try 3.5 and remove 4?
Old 08-25-2010, 05:21 PM   #11
speaker
hey. got the same error with my pc. seems like it's some kind of font issue. tried it on my mac with bootcamp and it worked fine. running windows7 64 on the pc and the 32 on the mac.
MA Fury 55 FBL Cgy 750
Next D Rave 450 Futaba 520
Align 450 Pro FBL Microbeast
Futaba 8FGS
speaker is offline        Reply With Quote
Old 08-25-2010, 06:10 PM   #12
Michaelinpr
I am running Vista 32 bit
Old 09-05-2010, 09:00 PM   #13
HiroboFreak
v4 is obviously the new version.
I'm running the 3G software under .NET framework v4 with no issues.
Sorry for the late reply.
| JR DSX9 Limited
Old 09-18-2010, 04:05 PM   #14
speaker
I've managed to fix my problem. I just had to install the "Arial Narrow" font and things were working fine.
Old 09-21-2010, 09:11 PM   #15
Michaelinpr
Where do I get the "arial narrow" font to install it?
Old 09-21-2010, 10:26 PM   #16
HiroboFreak
http://tinyurl.com/2vzbdwj
| JR DSX9 Limited
