Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters
Hirobo Nitro Helicopters Hirobo Freya Evo Eagle Helicopters Discussion
Old 12-13-2006, 07:16 PM   #1
glennlouise
Default Phasing Ring Problem on the EVO 50
I have read alot of posts about the phasing ring sliping / turning on the main mask causing all sorts of problems.
I have just picked up my new EVO 50 kit and there is a separate sheet attached to the instructions showing extra grub screws / bolts on the phasing ring which I believe is Hirobo's fix to the above problem.
Can anyone tell me if the fix has been successful or should I still consider getting the metal version of the ring?
Any feedback is appreciated.
Glenn
glennlouise is offline        Reply With Quote
Old 12-13-2006, 08:50 PM   #2
mudbogger2
The plastic one works fine. I used them for a long time before I upgrade to the metal on all 5 of the evo's I had. Don't overtighten them and strip the plastic though. Also adding a bit of green locktite to it will add a bit of extra insurance.
Jon Jennings
mudbogger2 is offline        Reply With Quote
Old 12-14-2006, 09:41 AM   #3
BarracudaHockey
The fix is ok, the metal one is the permanant fix.
Andy
AMA 77227
Jacksonville FL
BarracudaHockey is offline        Reply With Quote
