| SR Blade Helicopters (eFlite) SR |
Hey all. Does anybody have a replacement battery upgrade recommendation? Something with a little higher amp, weight, and price improvement that will still fit under the canopy and where I can purchase them. Thanks.
Doug
Phoenix Sim, Spektrum DX8 Trex 250 Pro DFC; Trex 450 Pro DFC Trex 500 EFL Pro; Trex 600 EFL Pro |
These are the ones I am using. They work great and the slight weight difference makes the heli balance perfectly. I just had to replace the connectors.
http://www.hobbyking.com/hobbyking/s...idProduct=9323 Edit: I also charge them at 2C which allows me to have them charged in roughly a half hour.
Helicopters: Blade mSR; Trex 450 Planes: Kyosho F-16 EDF; Parkzone F-27C Stryker |
There's a "Thunder Power Prolite" 1350mah that pretty lightweight. According to this review http://www.rchelicopterfun.com/blade-sr.html , the heavier the battery the more the rotor torque and so the more the tail motor works, so there might be tail issue tradeoffs if someone gets themselves a crazy heavy 2200mah battery. Might be more of an issue for hovering than flying about, but I've tended to go for lighter batteries.
MSH Prôtos, Trex 450 Pro EXI, mcpx, sr some planks dx8, phoenix |
Hyperion is my reccomendation. They just released a new 45C battery that's very competitively priced..
http://www.helidirect.com/hyperion-1...ck-p-19826.hdx
- 6S TREX 450 Pro FBL - µBeast, MKS DS95 and 8910A+, DFC Head, CC ICE Lite 50, 450MX 1700kv - mCPX - Spektrum DX7 |
Thanks for the replies everybody. Do these different packs require soldering, or are they crimp connections? It seems like none of these have the JST connectors.
Oh never mind, I see the Turnigy comes with the JST connections.
Phoenix Sim, Spektrum DX8 Trex 250 Pro DFC; Trex 450 Pro DFC Trex 500 EFL Pro; Trex 600 EFL Pro Last edited by kickbackkid; 08-22-2010 at 01:51 PM.. Reason: Upon further review |
#6 |
Almost all of the performance batteries will not come with any connectors on the power leads.. they are left for you to solder on, depending on what your setup is using. I suggest converting your SR/charger setup over to the dean's ultra plug.
