Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 08-26-2010, 05:10 PM   #1
knysna4
Default Place to mount FBL control unit?
I've been looking at the manual for the 90, (in anticipation of my build), and was wondering where to mount the FBL control unit. Will the (Optional tray CNC R90N825-SS) shown on page 17 of the manual, be offered in the FBL kit?
If not, I don't see any flat areas to mount the FBL unit on, except for mounting at the rear of the frame at the start of the boom, and that will be a PITA with all the wires.
The area for the gyro in the manual, looks too small for a FBL unit and all of the wires.
Anyone got any ideas!
knysna4 is offline        Reply With Quote
Old 08-26-2010, 05:40 PM   #2
Foxden
Yes, I believe the optional tray is going to be included and that is where I mounted a Spartan 760 in one of our Vel 90's and I think that is where Alvin mounted his Skookum 720 on his.
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote
Old 08-26-2010, 11:55 PM   #3
knysna4
Thanks Foxden, that's great.
Old 08-27-2010, 12:11 AM   #4
Jason_Adamo
There is a spot on the radio tray right in front of that CNC plate that kind of cut's down and it's a solid mount and the sk720 fit's perfect when turned 90 degrees.
TEAM OUTRAGE RC
TEAM SAVOX
SKOOKUM ROBOTICS
Jason_Adamo is offline        Reply With Quote
Old 08-27-2010, 09:36 AM   #5
knysna4
I will be using a BeastX, which although can be mounted on it's side, cannot be turned 90 degrees. It must follow a line from nose to tail ie wires facing nose or tail only.
Hopefully the cnc plate is included, as this position seems to be my only mounting option.
Old 08-27-2010, 01:22 PM   #6
Jason_Adamo
I believe the cnc plate is included in the production kits "optional" being if you want to install it or not. It's Simply a stiffener for the top portion of the frame.
TEAM OUTRAGE RC
TEAM SAVOX
SKOOKUM ROBOTICS
Old 09-11-2010, 11:56 AM   #7
guyro
Here you go:
guyro is offline        Reply With Quote
Old 09-11-2010, 12:37 PM   #8
knysna4
Thanks Guyro, looks great. Are those the new Outrage BLS servos on your cyclic??
Old 09-11-2010, 01:05 PM   #9
guyro
The Velocity 90 belongs to Eitan Goldstin, it has a new prototype TORQ servo's
Cyclic are 9180 and tail is 9188
Old 09-11-2010, 01:51 PM   #10
knysna4
Oh, got excited for a second, thinking that maybe they were released
