Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 08-27-2010, 09:21 PM   #1
byter182
Default Anyone tried transfering FPv1 parts to FPv2?
Hello Guys,
I have a old frame from my HBCP3 sitting around from when I replaced it w/a new one. Just got a little crack that can be easily repaired. Since the HBCP3 frame is the same as the HBFPv2 frame, I thought it might be a good idea to transfer all the components from the HBFPv1 to the upgraded frame. I know that definitely the tail boom is of a different diameter but I can pick one of those up. Other than the tail boom does anyone else foresee any problems?
Trex 500e Pro, i2 Head, VX1e; Trex 550e DFC w/Blue Full Vbar, 730MX
600e Pro Performace Upgrade w/Blue Mini Vbar, 750MX
Logo 600se w/Silverline Vbar Pro, PowerJive120, Pyro 700-45L
Yellow SAB WobblinGoblin770 w/ iKon v2, Red Mostro v1 w/ iKon v2
byter182 is offline        Reply With Quote
Old 08-27-2010, 09:46 PM   #2
HELIHANKSTER
Hi byter182
The V2 main shaft is longer than the V1 so you will need to get one and you will also need the 3mm main bearing set thats made for the V2. The bearing set also come with the spacer that goes between the bottom of the main gear and frame. Other than the boom and tail motor mount/tail fin...this should do it.
HELIHANKSTER is offline        Reply With Quote
Old 08-28-2010, 01:44 AM   #3
byter182
Originally Posted by HELIHANKSTER View Post
Hi byter182
Hey Helihankster,
Are you referring to these parts?
http://www.helidirect.com/esky-beari...12-p-19560.hdx
http://www.helidirect.com/esky-beari...in-p-19562.hdx
http://www.helidirect.com/esky-coppe...ch-p-15778.hdx
I also decided to throw in a set of Pitch Control Links just in case since the main shaft is a bit longer.
http://www.helidirect.com/esky-pitch...ch-p-15776.hdx
Might you know where I can find the HBFPv2 owners manual? Googling hasn't turned up anything for me.
Old 08-28-2010, 02:02 AM   #4
Viet-Lama
Check the stickies, there should be an excellent one on the conversion.
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 08-28-2010, 05:26 AM   #5
HELIHANKSTER
Originally Posted by byter182 View Post
Hey Helihankster,
Ooops…I forgot about the linkage. Yes you will definitely need the V2 servo pushrods. You should already have these bearings (first two links you posted) on your V1, but it wouldn’t hurt to replace them. The third link with the bearings with the copper covers are the ones you will definitely need.
This link should have the V2 manual
 http://www.heliguy.com/helicopter_manuals.html
Also here is the link to the sticky that VL had mention. I just checked it out...Stevespana did a awesome pictorial on the conversion.
http://www.helifreak.com/showthread.php?t=186528
Old 08-28-2010, 01:59 PM   #6
byter182
Thank you Helihankster & Viet-Lama,
Exactly the information I've been looking for. That thread is extremely detailed. I should be able to complete my project armed w/all the info I need.
Peace
Old 08-30-2010, 12:40 AM   #7
Viet-Lama
Your welcome and all we ask for in return is a photo of the completed bird
