| Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others |
I am going to replace the stock servos on my CP with another set of stock ones I have off a parts heli I bought. It is also a CP. My question is, when I center the servos, then install the horns, do the horns come straight out at a 90 degree anglewhen centered?
#2 | |
if you are using a stock radio you cant adj them. You just have to adjust linkage to keep swash plate level.
Trex 600cf, Trex 500, 450se & V2, Blade cp pro, Picooz |
OK. Thanx that's what I wanted to know. As usual the vast knowledge of the people here comes through again.
Fly it like you stole it. |
Since you don't have sub-trims (on the stock Tx). You can use the regular trims a little bit to TRY and get the servo arms a little more level before you adjust the links to level the swash. Mine won't go 90 in any position, but it helped a little.
TREX 450 SE, Pheonix 35 ESC, Medusa 028-032-3400, 13T pinion, HS 65HB, 401gyro-9650, Flight Power 25C 2170, Align CF blades. |
is it possible to use digitals on the cp? like the jrds285 or the futaba s3153. is there a point to such an upgrade?
