Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 08-29-2010, 04:14 PM   #1
RC'er
Default Stock RCE-BL70G ESC governor mode?
I am sending back my ICE 100 esc (loose heat sink) and putting the stock esc back on. How well does the stock RCE-BL70G ESC work using governor mode?
Scott
Trex450 sport -- Trex550 FBL -- Swift NX
RC'er is offline        Reply With Quote
Old 08-29-2010, 04:45 PM   #2
bobkra
I tried mine in "G" mode and it held a constant speed very well, but I could never get the speed to be where / as high as I wanted it. I use throttle curves instead.
bobkra is offline        Reply With Quote
Old 08-29-2010, 05:29 PM   #3
Wolfpackin
Align ESC's are known to have marginal governor modes.
Just run a shallow V, or flat, curve and I'm sure that will hold you over quite well.
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 08-29-2010, 09:18 PM   #4
helikev2
i 've always wanted to ask that question. thanks!
but does that add extra workload to the ESC that it heats up more?
Trex 450 Pro for 3D
helikev2 is offline        Reply With Quote
Old 08-30-2010, 05:37 AM   #5
Nko15
Short answer: Its crap. tested it on both the 70 and 100 amp align esc, and 1, the tail gets ticks(not a gyro+servo problem...)and it just doesnt hold the rpm's right.. at least not during soft 3d..
Nko15 is offline        Reply With Quote
