Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters
Compass Model Helicopters Compass Model Helicopter Discussion
Old 08-31-2010, 06:06 PM   #1
brian94066
Default my 6HV went in today
I was out at the local school doing some flying, mostly to get the Vbar dialed in
first battery pack was fine, i was checking gain and stuff and everything looked solid
then the 2nd battery, i push it a bit harder, i came out of a loop into forward flight, rolled 90 degrees to the right, and hit right rudder...the tail would not get past 90 degrees, and i couldn't save it in time
i think it was my CF tail rod flexing...sucks, it was flying great, and i still have a funfly in October
brian94066 is offline        Reply With Quote
Old 08-31-2010, 07:27 PM   #2
Cullen Colapietro
Sorry to see that Brian, doesn't look too banged up however.
Only Fine Helis | Buddy RC | KBDD
Cullen Colapietro is offline        Reply With Quote
Old 08-31-2010, 08:22 PM   #3
brian94066
i have most of the parts so it's fine, sucks it went in, i'm gonna go with the stock metal tail rod again, see how that works out, or i might just get more guides for my CF rod
Old 08-31-2010, 08:30 PM   #4
Cullen Colapietro
You know, I've been really happy w/ my stock tail pushrod. However, I've got CF rods I've built on my smaller helis. Stock works out well on the 6HV for me.
Old 08-31-2010, 08:49 PM   #5
Caleb White
Feel for ya... I've been there one too many times lately (not flight control issues though... I did have a build error on one )
So the frame is completely fine isn't it? That's what sucks most.. cracked frames.
Get it back up soon and take some video! I'm working on mine now, FBL
What a great hobby...even better, its people! Be blessed, friends.
Caleb White is offline        Reply With Quote
Old 08-31-2010, 10:10 PM   #6
brian94066
the 6HV is hard on the tail, any flex and you get into my position, should've known that, then i'd still have a flying heli oh well, i have time till the Helifreaks Funfly in October, i'll just play around with the Atom now, while the 6HV is getting fixed
Old 08-31-2010, 10:14 PM   #7
Ah Clem
Sadly, been there done that.
"You know, I've been really happy w/ my stock tail pushrod."
Agreed! Stock tail pushrod works great!
Old 08-31-2010, 10:22 PM   #8
TheBum
Speaking of which, how many guides are people running with the stock pushrod? I got something like 6 of them in the kit but only used 4.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
Old 08-31-2010, 10:34 PM   #9
Speed stick 3D
Im only using 4.. no problems here
AmainHobbies - Protek RC
Speed stick 3D is offline        Reply With Quote
Old 08-31-2010, 10:44 PM   #10
Cullen Colapietro
I'm using 3, strategically placed and they work great. I only have 2 on my Atom 5.5.
Old 08-31-2010, 11:13 PM   #11
brian94066
my old set up was 5, i'm so anal
Old 09-01-2010, 02:47 AM   #12
donskills
Using 3 here!! bullet-proof!
Henseleit TDR 2011, Spirit, BLS451/251,Pyro30-12, Kontronik Kosmik 200+Jlog2.6GW, Radix 710FBL, Radix 110 tails.
AccuRC, realflight 7, Jeti DS-16.
donskills is offline        Reply With Quote
Old 09-01-2010, 08:02 AM   #13
hornet dave
I'm betting it's just not enough tail rotor throw. If you haven't modified the spacers on the tail shaft, you will not have enough pitch on the tail rotor to do piros during fast flight.
http://www.helifreak.com/showpost.ph...7&postcount=16
hornet dave is offline        Reply With Quote
Old 09-01-2010, 10:04 AM   #14
brian94066
I'd have to check that, i am running stock spacers
Old 09-01-2010, 10:16 AM   #15
Caleb White
That's what I was going to say... and it may depend on tail blade/servo brands too... but mostly throw. Either shorten spacers 1-2mm or remove altogether.
Old 09-01-2010, 10:19 AM   #16
hornet dave
and there is nothing magical about the dimensions i've posted in that link. Im actually going to trim them a bit shorter when I get around to it.
Old 09-01-2010, 10:33 AM   #17
Daniel tengvall
I agree, I think it was becouse he lack of throw. When the tail stop did you pirruette counter clockwise? Trim down the spacer closest to the tail hub to increase the throw.
Some "low" numbers in the vbar can also affect the pirruette rate. Be sure you run at least 75 in I gain (to low will make the piro rate inconsistent). To low common gain can also make the tail hesitate while pirruette in winds and high speed.
Sorry about the crasch!
Daniel tengvall is offline        Reply With Quote
Old 09-01-2010, 12:21 PM   #18
brian94066
I was piroing counter clockwise, yes
I'm gonna take the spacers out altogether and get 45 degrees left and roght deflection, that should solve the problem
Old 09-02-2010, 05:41 AM   #19
Speed stick 3D
Im not running any spacers on mine.. Been fine
Old 09-02-2010, 11:58 AM   #20
Ah Clem
I think that the manufacturer included the spacers because some people were putting too much throw in the tails of the older Compass machines. I suspect this was their way of preventing the issue of people setting them up so that there was binding or locking due to going over center.
