Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Quick of Japan
Quick of Japan QJ Helicopters
Old 09-01-2010, 10:45 PM   #1
PAS
Default 420mm blades on a EP8v2SP?
Does anybody have any first hand experience with 420mm blades on a EP8v2?
I had some bad luck with the QJ 400mm CF blades and want to try something else.
For details see this thread: http://www.helifreak.com/showthread....30#post2306230
Are there any other brands that make 400mm blades that fit?
Thanks!
-Paul
Compass Atom 500 to replace Quick of Japan EP8
Dragonus II N-Plus
Gaui 330x-S
PAS is offline        Reply With Quote
Old 09-04-2010, 03:28 PM   #2
Henry
I will look into this and let you know. If I rememger correctly, MAH has a set of blades that work nicely. How about Curtis Younblood blades?
Henry is offline        Reply With Quote
Old 09-04-2010, 04:22 PM   #3
PAS
I am mostly concerned about using 420mm blades with a standard length tail boom.
I don't want some kind of crazy tail and main blade interaction.
-Paul
Dragonus II N-Plus
Gaui 330x-S
Old 09-04-2010, 05:07 PM   #4
Henry
-Paul
Try the MS Compsit 420s. Helicopter Hobbies should have tjem in black or white.
Old 10-11-2010, 09:41 PM   #5
quickfighter
I want to say that I have run the MS Composit 420mm rotor blades for the past 3 years. They are the best running blades I have ever run on my EX. I run them on my SP and they were great. The white blades are a little lighter than the black CF blades and they are just as stiff. I must say they added about 1 minute to my run time on my EX. I got an extra set for my EX from Charles of Helicopter Hobbies.
Harold
quickfighter is offline        Reply With Quote
Old 10-17-2010, 11:42 AM   #6
smaner
Default 420 MS COMPOSITE BLADE
What a coincidence, I just so have a set hanging on the wall that I'll let go for $40 shipped...What a deal!!!!!!!!!
smaner is offline        Reply With Quote
