Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 09-02-2010, 05:34 PM   #1
matt blaisdell
Default brushless cp pro2 for sale
blade cp pro 2 with upgrades all brushless
ok guys here you go im going to eat one on this all brushless e-flit 4100 kv motor and portion neu tail motor
MicroHeli Precision Main Gear W/Hub, futaba 401 tail gyro i have , hobby wing esc and gaui 10 amp tail esc.
just has had no luck. so it has to go. have over $500.00 into it. it also comes with everything in pic also stock transmitter thats in the box. $200.00 shipped (conus). every thing is new also comes with 2 e-flite chargers and 2 e-flite batteries
TEAM:
CYCLONE BLADES
matt blaisdell is online now        Reply With Quote
Old 09-22-2010, 01:01 AM   #2
HALO 3
I bought this heli, very clean setup Thanks Matt but I cant get the tail to even work it just spinns around anybody have a clue thanks
HALO 3 is offline        Reply With Quote
Old 09-23-2010, 07:45 AM   #3
John Shipley
I have the same tail set up. It sounds like you either have the motor wires backwards or the reverse switch on the gyro backwards. I test by taking off the head....so you don't get hurt with the blades turning. I then spool up a little and move the heli nose to the left, the tail motor should come on and try to push the nose to the right. Make sure the motor is turning in the right direction first. If the motor is not going in the right direction switch 2 of the wires. If the motor is turning in the right direction, but the gyro does not push the nose back to the right when you move it left, reverse the swich on the gyro......PM me if this does not work........ Your delay should be all the way up and your limit is 60%...........J
John Shipley is offline        Reply With Quote
Old 09-24-2010, 09:39 PM   #4
HALO 3
Thanks John I was just goin post that I figured it out Exactly except that sometimes the tail swings to the right without me doing anything at all. I goin to put the delay up all the way. Thanks John
Old 09-24-2010, 10:03 PM   #5
HALO 3
did it, but the tail still kicks to the the right when I push the stick to the right. Naturely it suppose to, but the tail go slightly to the right ,and then all of a sudden it kicks hard to right without me doing anything at all.......any ideas ????????????
Old 09-28-2010, 05:46 PM   #6
John Shipley
The gain on you 2n1 is too high. Your gyro sends or stick sends a signal and the the pot on the 2n1 magnifies it. So turn the the pot counter clockwise.... a little at a time..J
