Go Back   HeliFreak > R/C Helicopter Support > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 12-18-2006, 05:33 PM   #1
Charley Stephens
Default Rotorworkz New 7.0 Lbs achievable T-600 frame kit
Gents here is a New frame I plan to release within days.
Ready to fly weight of this heli with Flight power 6s1p 4900 is 7.0 lbs = 3.175 kilogram
Cool Features are
1. Top mounted motor. Now you can add long lipo packs
2. I removed all bell cranks and replaced with direct linkage with Futaba 9650's the same servo's guys are using in Logo 14's.
3. Added 2mm Press in nuts so no more align plastic gizmo's.
4. Custom adjustable servo linkage arms that mount to your stock wheels
Note this is a prototype so general apperance and/or items may be located differently in released version.
Charley Stephens
Charley Stephens is offline        Reply With Quote
Old 12-18-2006, 05:35 PM   #2
Finless
Team Taco VP
WOW Charlie... looks good!
I would love to do some 8 and 10S testing on THAT set of frames!
Man 1/2 pound drop! I want one
Bob
Old 12-18-2006, 05:42 PM   #3
ozace
Looks good Charley, not a path i can take as this requires new servos but for someone wanting a light weight hipo machine
more than enough now
ozace is offline        Reply With Quote
Old 12-18-2006, 05:44 PM   #4
Finless
Team Taco VP
I bet this frame andf the 8S setup we are testing would ROCK man!
Sheesh it looks like it is going to be a POCKET ROCKET
Bob
Old 12-18-2006, 05:51 PM   #5
WillJames
Registered User
Let us know once you get it flying Bob.
William James
WillJames is offline        Reply With Quote
Old 12-18-2006, 06:02 PM   #6
Charley Stephens
During my test flights it did quite well with that stock 600L motor for the same flight time/routine I used 400 mah less out of the pack. I can only imagine when I get my NEU motor how alive this beast will become :twisted:
Charley Stephens
Old 12-18-2006, 06:11 PM   #7
Bjorn
Seems like the pushrods is'nt parallell withe the mainshaft? Could one expect som interactions between the servo's because of that? If so can this be mixed down to zero interaction?
Team visa.....
Bjorn is offline        Reply With Quote
Old 12-18-2006, 06:17 PM   #8
Finless
Team Taco VP
No.... as long as ALL links have the same angle then no interactions. What you might get is a "delta" which means you may have different feel from center to above or center to below. Realize servo arms make an arc... so now way from full pitch both ways are the links always going to be parallel to the main shaft. At center stick they could be but as you increase pitch or or decrease pitch the angles will change!
Bob
Old 12-18-2006, 06:22 PM   #9
Bjorn
Well, maybe I'll sell my roxxter55 now that there seem to be a good alternative with cheaper parts :-)
Team visa.....
Old 12-18-2006, 06:22 PM   #10
Gscott
Does the canopy fit over the top mounted motor?
Gscott is offline        Reply With Quote
Old 12-18-2006, 06:25 PM   #11
Charley Stephens
It does require trimming the canopy for the long motors such as the stock one. for the short outrunners should not have to trim.
Charley Stephens
Old 12-18-2006, 06:31 PM   #12
Bjorn
How about a plettenberg orbit 30-12? Would I hav to trim the canopy for that one??
Team visa.....
Old 12-18-2006, 06:38 PM   #13
BoneDoc
Can you make the servo pocket bigger to accomodate regular size servos? You'll have more options that way.
**If you ain't crashing, you're not flying hard enough**
BoneDoc is offline        Reply With Quote
Old 12-18-2006, 06:42 PM   #14
Greg Alderman
Damn Charlie...if these are anything like you stock replacement frames then they will be great...Loving the stock G-10 ones I got from Modefo's
Bob...hmmm...8S sounds awesome at 7lbs!!!
Greg Alderman
Manager, Prestige RC
greg@prestige-rc.com
Kontronik USA Service
repair.USA@kontronik.com
Greg Alderman is offline        Reply With Quote
Old 12-18-2006, 06:44 PM   #15
BoneDoc
Bob
But that would still be the same even with the bellcrank right?
Old 12-18-2006, 06:44 PM   #16
Bjorn
http://www.helifreak.com/viewtopic.php?t=26068
Hmmmm, now I have to choose......
I tought this would be easy... :?
Team visa.....
Old 12-18-2006, 06:46 PM   #17
Ticidytoc
From what I can tell the Orbit will be close, the Z-Power should be no problem. I'll let ya know in a few days.
Bob
LOL
If the 8s will Rock, then the 10s will ....??? :twisted:
A Helicopter, Brushless Motor, Esc, Battery, Servos, RX
Ticidytoc is offline        Reply With Quote
Old 12-18-2006, 08:05 PM   #18
Charley Stephens
With this design and layout Full size servos won't fit in the area of the 9650
1st they hit the mainshaft
Second the bearing blocks are to close together
Charley Stephens
Old 12-18-2006, 08:09 PM   #19
Finless
Team Taco VP
Funny you should say this.... EXACLTY what I was thinking man... FREAKIN POCKET ROCKET with Charlies new frames!
Charlie and I just got off the phone talking about the ULTIMATE Trex setup.... I wont say now but your DAMN close in the thinking
Charlie is looking to save weight, increase flight time and performance. I am doing the same but trying motors to do the same. Between the 2 of us.. WTACH OUT... A desire anyway
Bob
Old 12-18-2006, 08:18 PM   #20
TomSardea
Hi,
What servos do we need to use w/your new design? 9650? any other options?
Thanks!!
Tom
Fusion
TomSardea is offline        Reply With Quote
