| Outrage 550 Outrage 550 Helicopter Factory Support Forum |
I recently received the brand new Flybar Lock designed specifically for the Outrage 550 by Rick at RDLohr's Clearly Superior Products. Since I had previously been using the allen wrench through the see-saw trick, it was a joy to get my hands on a proper tool that was intended for this job.
First off, the tool works exactly as advertised. The fit is fantastic as it locks the flybar firmly in place while you adjust your pitch ranges. It is simple to use as demonstrated in the provided instructions. Some of the CNC machined edges were a bit rough and unfinished, but could easily be sanded or filed to improve the finish if desired. In fact, Rick mentions in the instructions that the pieces can even be filed a bit if the fit is too tight. I didn't find that necessary as the pieces fit snugly in place as advertised. The only problem I found about RDLohr's Outrage 550 Flybar Lock is the size. While it's nice to have a small, compact tool that can be thrown in the tool box, it's almost too small. Especially since it's made of clear lexan! The tiny pieces could easily get dropped or lost. I'll probably use a sharpie to color in the raw CNC areas for visibility, but I think a simple twist tie looped through the holes holding each piece together will be the best approach when it comes to keeping track of this fantastic tool.
Outrage 550 Silver Pro ** For Sale ** - Neu 1907H/1Y, Spartan Quark, Align 610's cyclic, 650 tail, ICE 100, CC Pro BEC, Z-Weave mains, KBDD 92mm tail, AR7000 Hirobo Sceadu Evo 50 (SOLD) Last edited by ksmith0034; 09-09-2010 at 07:10 AM.. |
Excellent. Glad you like it!
The holes you mentioned are there for exactly that purpose, to keep all three pieces together. As far as the rough edges, the side edges are actually smooth, but the very top of the edge is left with a very thin artifact left over from cutting them. I remove some with my fingernail, but its too time consuming for me to remove them all and still keep my price low when making a lot of them. It doesn't affect how they work, but I end up removing them on my personal tools. Thanks for the thorough review. I love to hear how my parts work out for people. Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I just received my Outrage 550 Pro Flybar lock from Rick tonight, and it would redundant for me to review the parts because Kevin nailed it right on the head.
Unfortunately, I wont be able to use it right away, as I wont be starting the build for a few weeks. The parts are great, thanks Rick. Kevin, your pics are missing.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Your welcome Bryan. Thanks for setting me up with a head. This one was fun to design because it was a bit of a challenge.
Rick
Hey Rick,
did you make one yet for the Vel 50? if you had the FBL for the 550 it is the same head that comes on the Vel 50
Clyde Fox Port Charlotte, FL. Team Rotorworkz/Outrage |
#6 |
I fixed the pictures. Thanks for the heads up Bryan.
Outrage 550 Silver Pro ** For Sale ** - Neu 1907H/1Y, Spartan Quark, Align 610's cyclic, 650 tail, ICE 100, CC Pro BEC, Z-Weave mains, KBDD 92mm tail, AR7000 Hirobo Sceadu Evo 50 (SOLD) |
#7 | |
Gaui X5! Outrage G5 x2 Blade mCPX BL & Blade mQX MultiWii Quadrotor |
#8 |
Can you post more pics from different angles?
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451 Last Rebuild: 10/15/12 (O550) |
#9 | ||
Rick
#10 |
take your time rick. im not in a huge rush. i used a flybar and double checked with a digi gauge which was 2* off . im still waiting on the new case so im good but need a replacement becpro v2 now . does it ever stop?
#11 | |
No, it never stops! Rick
#12 |
Rick has some other pics posted in this thread:
http://www.helifreak.com/showthread.php?t=237703&page=2
#13 |
Was this what you had in mind?
#14 |
rick perfect thats exactly what i was thinking -perfection-- umm can you make a dash for a 68 camaro outa acrylic ? just kidding.
#15 | |
Rick
#16 |
He is a view looking more FBL like since its an FBL Alignment Tool.
Rick
#17 |
im impressed
i think that may be a big seller too its not hard to tape the flybar to the button but its a pain in the a@@ to get it level on the tape this setup fixes it and i can use my 10 dollar pitch gauge again thats more accurate than my digi box thats 2* off all the time . |
#18 | |
Rick
