Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 09-09-2010, 11:29 PM   #1
Blink 182
Default Painting stock canopies
I have a stock yellow canopy for my 700 and I want to paint it.
What type of sand paper will i need to use to sand it? What type of prep do i need to put on the canopy before actually painting it?
(・ω・`) ギルティクラウン
Blink 182 is offline        Reply With Quote
Old 09-09-2010, 11:52 PM   #2
AnthonyJr
Wet sand it with 320 wet/dry sand paper, primer it, then have at it.
GrandRc
AnthonyJr is offline        Reply With Quote
Old 09-10-2010, 01:03 AM   #3
Blink 182
To wet sand you just run water over it while sanding right?
(・ω・`) ギルティクラウン
Old 09-10-2010, 01:10 AM   #4
AnthonyJr
Yes, but I just dip the sand paper in water. Just make sure you keep it wet.
Take progress pics! Good Luck.
GrandRc
Old 09-13-2010, 09:24 PM   #5
SQRT(-2)
Oh my god, what is a Stock canopy painted with????
I have sanded it, and sanded it and even taken a drill mounted wire brush to it and I can't get it off. (Alighn canopy btw)
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 09-13-2010, 10:34 PM   #6
AnthonyJr
Don't try to remove the paint.
You sand it to rough up the surface to reciever the primer coat. For the primer you can use rattle can enamel.
Sent from my HTC HD2 using Tapatalk
GrandRc
