| Thunder Tiger Electric Helis Mini Titan E325, Raptor E550 and E620 SE Helicopters |
#41 |
My set up is
Thunder Tiger Mini Titian E325 Obl29/35-10H w/ 11t Castle Creations Phoenix Ice 50 ESC HS65HB x3 InoLabs D261 HB Detrum GY48V Spektrum DX6i normal : Sport Thro cur 0 50 80 90 100 Pitc cur 35 46.5 60 80 100 Mini Titian E325 / AH-1 Cobra Obl29/37-10H w/11t Exceed RC Volcano 40A ESC HS65HB x3 InoLabs D261 HB Detrum GY48V Spektrum DX6i normal : Scale/Sport Thro cur 0 45 65 85 100 Pitc cur 35 42.5 50 75 100 |
#42 |
hello my mt is what I have so
SAVOX cicliclo servos queued servo SAVOX 12t engine sprocket 3550 gyro zxy normal gas curve 0/100/100/100/100 beautiful flies |
#43 |
my mini titan
TT E325 V2 FBL Savox sh 0257 mg cyclic servos Savox sh 1257 mg tail servo Stock motor and esc Tt carbon main blades, kbdd tail blades Carbon and aluminum parts that the kit didnt come with Tarot zyx-s and spektrum dsmx satellite Controlled by dx8 Just setup the fbl gyro but scared to fly it until i can havesomeone look it over Any settings and advice will be appreciated |
#44 | |
if so will try to help greetings |
#45 |
Aloha Jac,
I just downloaded the new 3.5 version software that dr.M provided here http://www.0577mx.com/news_view.asp?clsid=15&id=268 and downloaded the fbl programming software, http://fbl.net.nz/ ,after that i started with a mild 3d preset and adjusted cyclic d gain to 10 as dr.m stated and just followed the rest of the setup... cant really let you know how she flies cause i havent dug out my balls from the hanger there is alot of info here http://helifreak.com/showthread.php?t=342434&page=129 and here http://www.rcgroups.com/forums/showt...12179&page=270 hope this helps as i know how stressful it can be for a first fbl gyro! Good luck |
#46 | |
#47 |
It seems like it's a work in progress constantly, but here's what I have right now.
v1 body various metal head upgrades CanoMod canopy JR DS285 on cyclic GY401 Gyro Futaba S9650 tail servo CC Ice 50 ESC Scorpion HK 2221-8 motor Thunder Power batteries Walkera Devo 8S + RX802
TT Mini Titan FBL v1, Ikon, Devo 8s V120D02S, Genius CP, Devo 7E Phoenix |
#48 | |
Wonder flies is a video Battery is a torpedo with 6 elements http://www.youtube.com/watch?feature...&v=NftwX8z06VM |
#49 |
Well, it is nothing special, but. . .
Mini Titan e325 V1 Savox SH-0257MG X3 GY48V Gyro - DY-1017 Align DS425M CopterX (CX-ESC-40A) HobbyWing Switchable U-BEC 3A 5/6V V3 Turnigy Typhoon 2215H Brushless 450-Size Heli Motor 3550kv w/13T Pinion 325mm PRO 3D CF main blade Thunder Tiger Rotor Spacer E325 V1/V2 I really like how it went together. No hitch save I had to file the mount for the rear cyclic servo a bit. It flies really smooth. It is trying to win my heart away from the Trex PRO.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
#50 |
I fly mine with people with the t-rex. Most say if they had of seen my mini titan before buying they would of got a mini titan instead. I fly mine in up to 35km/hr winds and it flies like a dream.
Sent from my HTC One V using Tapatalk 2
B400(retired) Mini Titan V1 Radikal G20 |
