| Outrage 550 Outrage 550 Helicopter Factory Support Forum |
I cant believe i'm considering this, but given light to what i have seen over the last several weeks, if I switch my ESC over to a Jive100, would the built in BEC be sufficient for high speed digital servos and FBL such as Align DS610 or Inolab 760mg or even JR8717?
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) |
Well I did a little more diagnostics, my ice 100 is bad. I hooked it up via internal bec, and a different rx out of my 450. My brownouts are even worse, and still get the same 5 bleep error code.
So if you can afford it vs having a crash maybe the 400 dollar kontronic is a solution, but an expensive one. |
I'm sorry to hear your ICE100 is bad. Mine caught fire the 2nd week I owned my Outrage! Almost lost it if not for my cat like reflexes.
I mean I'm really pissed when 150 to 200$ esc fails but I'm going to be livid if 300 to 400 esc fails and causes me to crash too or better yet sets my new heli a blaze!
Yeah, I bought my 550 used and then had to buy the electronics. I bought the castles stuff new, and I thought I was buying good (and expensive in my opinion) stuff with the castle gear.
Honestly, im not gonna spend 400 bux on an esc. Id sell my stuff and quit the hobby if things cost that much. hopefully I can get an ice 100 soon since they are having other problems. Ill call cc tomorrow and talk with someone and see what they have to say. |
#5 | |
Ok back to my original question does anyone have any comments on how the Kontronics BEC will work with Align DS610's or Inolab760mg, jr 8717 etc...
#6 |
I run a Jive 100LV but I also use a WR Hercules BEC, so I don't know first-hand if it will run. Popular consensus is to run an external BEC regardless of the ESC. From previous research, Kontronik tends to under-rate their products, so I'm sure the internal BEC is adequate and if I had to, I wouldn't have a problem running it. I just prefer to compartmentalize everything so that I can run it down in my head and troubleshoot it.
SV, as for the cost of the Jive, if you can find a used one for around $200, snatch it up. You just have to keep an eye out. I bought a used one that was partially melted for $120 and sent it in for repair because the battery leads were too short. Kontron couldn't repair it, but sent me a new one for $100. So I was out of pocket $220 for a new Jive. Probably a little more than the ICE, but they don't have nearly the troubled history as the Castles. However, it does have its own issue, which I won't expound on here, but it's not nearly as bad as spontaneous combustion. ![]()
600G Helibug: Vbar 5, Torq 9080s, Torq 9188, G290RC, GV1, Jewel Trex 450 Pro: Vbar 5, Hitec 65s, JR 3500G, Scorpion 2221-8, Kontronik Jazz 40 |
#7 |
I have a Scott Gray ReactorX and Western Herc Super Mini BEC. Both of them are nice but I have to admit I perfer the design of the CC BEC PRO that i'm sending back to castle. The western lets you pick from 5.3 or 6v which ends up acutally being 5.2 and 5.8 v on a fresh battery according to my telemetry
I am at a loss what combos i should be running for best reliability. I have had 5 crashes over 2 different helicopters last month all caused by malfunctioning equipment, none by my hands. Each crash has easily cost me on avg 75 to 100$ to repair plus hours of time chasing down the problems which is the highest cost to me. I now understand why everyone buy HV servos now...this hobby is starting to get a little expensive... ![]()
#8 |
I run the internal jive 100lv bec on my new logo 500se with bls 451 and 251 plus mini v-bar without any issues. The jive 100lv is an awesome esc.
Logo 500SE mini V-Bar 10s 3DHS 48" edge 540, HK P-47 63", HK Cessna 182 73" DX8 (Waiting for DX18) Skype: LogoFreak |
#9 |
So far I have 3 yes for internal BEC and 1 no. I will give it a try and see. Maybe I will get some logging to monitor my voltage or setup my cyclics on the bench with my tester and stall them to see how much voltage one draws. Boy i am looking forward to getting in 2 consecutive flights without me cursing out Castle!
#10 |
I have had my 550 for over a year using the internal BEC to run three 8717s and a DS8900 through the Vbar system. Works great!
#11 |
I'm sold on the internal BEC!!
#12 |
So do you have any feedback on the internal BEC? I'm thinking of running it on mine so that I can move my Super BEC over to a second ship to run with a YGE controller.
#13 | |
It was a similar setup on a friends rex700e conversion with vbar that convinced me to run my 3 inolabs (said to be power hungry) + mks tail & microbeast on the jives internal bec & its all good. I have however set the bec to output 5.8v as i heard some time ago that running 6v was causing some issues on the v7 escs. Mine has been updated to v9 but i'm sticking with the evil i know, 5.8v & she still flies like a beast.
Shape 9.0, Goblin 700 (yellow & orange) , Outrage G5 all FBL** MKS Cyclics & Rudder Servos all round. Futaba SBus Rx, Futaba 8FG** transmission. |
#14 |
I didn't realize you could specify voltage by tenths. I thought it was either 5v or 6v. Do you need the card to do that?
#15 |
Yes you need Prog Card 2 to choose voltage. I ran the internal Jive BEC without issue at 6v. I was a bit nervous at first but I've learned that if you cant trust the German electronics what can you trust!! lol If I am going to run a bec it will be the Kontronic one else i'm going unregulated.
#16 |
6v? cool, think i'll step mine up & see how she goes.
#17 |
I had not heard of any issues with 6v, but i do have a v9 jive so I guess i wouldn't matter anyway. I cant see what difference 5.8 vs 6v would make regarding problems.
#18 |
I have the Jive 80HV on the verison 9 and I am running the internal BEC, but have thought about running a separate battery just to be safe. I know the German made stuff is great, but is it really safe to use the internal BEC? Also, I thought the default was 5.6v not 5.8v. I am using the default settings on it at the moment since I don't have a programming card.
I am running 8717's on cyclic and a 8900G on the tail, so I think I should be ok. Also, can anyone tell me the difference between the verison 7 and verison 9? What changes were made? I ask because my buddy has the 7 and I was curious!
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!! No helis right now! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Maybe I'll be back in another year! |
#19 | |
Yes the default is 5.6v but if you have the program card2 then you're able adjust the bec voltage as follows: 5, 5.2, 5.4, 5.6, 5.8, 6v. Believe me & the many others out there, you are perfectly fine using the internal bec even if you were running a FBL unit as i am. The Kontroniks have a safety feat to aviod damaging the esc, this feature on some of the v7 units not all the cutout was triggered prematurely causing motor shut down also some units were losing settings when unplugged so you had to reprogram in the settings. This was solved with the v9 update, fortunately i never experienced any of these problems.
#20 | |
Sent from my Droid using Tapatalk
