Old 09-15-2010, 02:47 PM   #1
Brett74
Default power supply posts out Stainless bolts vs copper ?
I am building a big power supply system for my chargers and need some bolts probably 10mm, going through the enclosure to some copper distribution strips 5mm thick 20mm wide, what materials should these bolts be made out of, they will see 100 amps at the most, do I need copper bolts or can I use steel bolts ? Is stainless better than mild steel ?
Any advice as far as electrical conductivity of diff material bolts is welcome.
Brett
Goblin 770 4540 395 Sig 16S YGE 160UHV VBar (gov)
Goblin 700 4530 540 LE 12S Ice 2 160HV VBar (gov)
Brushless MCPX
Brett74 is offline        Reply With Quote
Old 09-15-2010, 04:04 PM   #2
azheliguy
Brett, Just off the top of my head I would say use copper.
But if you use steel I would use stainless steel. That way it will not rust.
T-Rex 600 ESP 12s, V -Bar 5.0 , Scorpion 4025-630, 610's, 8900G, CCIce 80HV, Hercules Bec
azheliguy is offline        Reply With Quote
Old 09-15-2010, 04:10 PM   #3
Brett74
Any good sources for copper bolts then ?
Brushless MCPX
Old 09-15-2010, 04:19 PM   #4
cbdane
You have to worry about electrolysis effects from high currents and dissimilar metals so I'd don't think I'd use stainless (which has iron content). In my opinion, your best bet would be brass which is more available, more durable, and very compatible with copper.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 09-15-2010, 05:49 PM   #5
azheliguy
Brass is a good idea.
I found some at McMaster-carr
http://www.mcmaster.com/#cap-screws/=8v1jvu
