| Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
I have a Trex 600 CF converted to 12S with torque tube upgrade. I also have a A 3G head and flybarless system. The helicopter flies great with only one bad issue. While doing front or back flips, the helicopter gets a real nasty aileron wobble. Once you return everything to nuetral, the wobble will eventually stop. It is a VERY bad wobble. I thought several times the heli was going to shake itself apart. I have upgraded just about everything on the heli except for the main bearing blocks(still plastic). I believe the problem is within the 3G settings. Any advice on 3G settings on the computer would be great. Thank you
#2 | |
Thanks for the advice. The 3G is set for 500-700 heli. I will lower the gains to 10 O'clock and start working my way back up. This is a new problem for me. This is my 5th 3G heli and I have not ran in to this problem before. Anyone else have any ideas?
yea, I agree it seems the bigger the heli the less you need to mess with any setting on the computer. I would suggest moving your gyro, if no resolution, stop gain for ele/ail took the shake out of my gaui 200 on hard tic toc stops. But it was very specific. Took a few days of flying and tweaking to find the sweet spot.
Team Radix/// |
