Old 09-15-2010, 08:17 PM   #1
xfactor6
Default Beastx on velocity 90 need some sugestions
what would be the best way to hook up the beastx to a jr 921 receiver multigov pro ds610 servos 650 tail 620 throttle. What regulator should i buy and what voltages should I run the servos/ equipment at?
xfactor6 is offline        Reply With Quote
Old 09-17-2010, 04:02 AM   #2
MaSt0RaS
i think that the best reg for this situation is the reactor X or the gryphon!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote
Old 09-19-2010, 01:28 PM   #3
raptorwoody
I am running this regulator (http://www.experiencerc.com/store/pr...ro-p-1508.html) on my Trex 700N with a 921 receiver and Align Governor with no issues. If you don't want to have the adjustability use this regulator (http://www.experiencerc.com/store/pr...ut-p-1507.html). In all practicality, you could just use a straight 6v regulator (http://www.experiencerc.com/store/pr...3E-p-3932.html). Since all your servos are good for 6 volts, it is a KISS setup!
raptorwoody is offline        Reply With Quote
