| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#21 |
The gaui hurricane 200 is pretty much the same size as a trex 250. Boom is slightly shorter thats about it. Many 250 parts can be adapted to work on the gaui.
-Phil, AMA #954735 |
#22 |
Yep both the 250 and 200 swing 205mm blades the 255 uses 255mm blades.
Compass, ProStar Hobby, Giant Power, OnlyFineHelis, Protek/Amainhobbies 7HV, Warp, 3D+ Lincoln To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. ):> |
#23 | |
The Blade400 is a great starter heli, its easy and cheap to fix, and perfectly capable of doing pretty much all manouvres, but the all plastic parts all have a little bit of flex and slop in. I bought a Trex 450 Pro super combo (before sport came out, which is probably a better heli due to robust belt tail and easier layout for maintenance) which I was scared to crash to start with, but soon got over that and ended up selling the Blade400 (I had bought it used, and sold it on for what I'd originally paid for it). I then ended up getting a Trex 250, which was fantastic, main benefit was I flew the 450 maybe once a week, not even every single week, the 250 I could fly several times a week, sometimes every day, wherever I was and my progress was so much faster for it. I still fly the 250 more than any other heli, I probably get 10 flights a week EVERY week with it, whereas the 450/500 probably get 10 flights a month, as I can only fly them when I get to the field. The 250 I can fly on any bit of open space, and is in a briefcase with tx, batts, charger, tools so I can chuck it in the car whenever I am away anywhere and more often than not there is somewhere I can fly it. |
#24 |
I think you should look into the gaui 200 if your looking for a small indoor outdoor ride,
alot more durable than your 250 and overall read about what people have to say about it. Good luck with your decision.'JC |
#25 |
http://www.aeromicro.com/GH100SE.htm
Perfect for Indoors if you have the skills. I want one too but I have enough for now. smaller than a 120, larger than MSR, and the body of a Gaui..... lol What am I doing here I don't even own a 250.....
Align: 6s FBL Trex450 Sport (a lot to say) E-flight: MCX 1 & 2, MSR, SR, SR120, MCP X To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#26 | |
(just razzing a flying buddy)
Got Freak? Paul Sr. "There is not much difference between pipe and tubing" BEAM E4 ~ds760+S9257~HS-5065~2221-8~ CC45~Eagletree+GPS 250SE~CC25+Scorpion 3900~HS-65HB~Quark~DS290~All metal ugrades~KDE Last edited by Cadjocky; 10-04-2010 at 03:48 PM.. |
#27 |
Razzing....
#28 | |
#29 |
Same thing here too. Most every morning at work in the parking lot before it fills up. 450 is my weekend worrior.
Got Freak? Paul Sr. "There is not much difference between pipe and tubing" BEAM E4 ~ds760+S9257~HS-5065~2221-8~ CC45~Eagletree+GPS 250SE~CC25+Scorpion 3900~HS-65HB~Quark~DS290~All metal ugrades~KDE |
#30 | |
#31 | |
#32 | |
i can fly my 400 in 20mph winds it's not fun, i can fly the 450 in 20mph winss and i still enjoy flying it cus the wind only bothers it a little bit.. hands down the 450 is a grat flying good quality machine, the blade 400 is just a semi ok flying, low quality machine unless you got a lot of money to dump in to ing i am ready to sell mine and gett a 250 or a 450, i love my 500 but it would be nice to have a back up and somthing to fly in smaller spaces.. |
#33 |
i ordered a trex 250 clone should be here in a couple days. can't wait to get it in the air. it's my first heli, so it should be interesting
#34 |
If u get a clone, make sure u change a few stuff. I would recommend these 2 items
Metal Tail Drive Gear Assembly H25079 New Main Drive Gear/120T H25096 Which clone did u get? I got the combo for the Flasher 250. Quite ok, but i need to change those as the plastic tail drive gear are just crap. even after i applied CA. Main gear was a bit warp. So for ease of mind, i decided to change it. Might as well get some stuff from infinity hobby, kevlar belt and CF boom
T-REX 450 SE MD500 (SE-maiden 15/03/06) (XL-maiden 16/10/05) T-REX 500 ESP (maiden 25/09/2010) Flasher 250 (maiden 13/09/2010) RAPTOR 50 TITAN (maiden 16/06/2006) Last edited by eerie; 10-07-2010 at 08:51 AM.. |
#35 |
Just destroyed my B400, the tail just died. and earlier this week I was just thinking of getting into a Trex 250 or a clone and dumping the 400. I have just started doing some forward flight circuits and the ocasional flips. The blade is going to need a new head and tail. I could get into a clone for what I am about to spend to repair the blade (metal parts). Someone help me descide.
