Old 09-17-2010, 05:20 AM   #1
toby2198
Default Inconsistent piro rate
Hi,
When doing piro's on my 600 3g, the heli spins around half way and then stops for a split second, then continues spinning. It is almost like there is not enough pitch in the tail blades to overcome the torque.
I dont think the tail pitch is the problem, but that it is a 3g setting. Does setting the "piro compensation" to high effect this or are there any other settings I should try to change?
toby2198 is offline        Reply With Quote
Old 09-17-2010, 07:10 PM   #2
jondabear
Yes. Too low of a tail gain will also cause this behaviour.
jondabear is offline        Reply With Quote
Old 09-17-2010, 07:41 PM   #3
oldschool269
as will to low a hs ...
jason
oldschool269 is offline        Reply With Quote
