| CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support |
#21 |
i have my tail gain and Governor and FC all on the idle up switch
normal mode is no FC gain with a mix like the one shown for the Governor this means you need a mix to have some FC gain using T hold but as far i can see this only leave you with a 3 position switch for the auto trim not that i/we can use it am using JR radio with gyro menu and Governor menu
2 x Blade MCPX,stock & duel Brushless Trex 250FBL,BeastX,Scorpion,Trex 450,Scorpion,4s,Jazz esc,Trex 500FBL,3GX V3.1,5s,Scorpion Avant, Kasama head,OS 91 OMI,XeroG Raptor,Total G,Outrage Head Trex 600 EFL Pro super combo,BeastX |
#22 |
Make sure that when setting your low throttle that you set the trim to 3/4. I am running a V-curve in Idle 1 and 2. failed to do this and noticed that around center stick it was going into decay mode. I went back and set the low throttle again and it took care of it.
Eric To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 600 / Logo 700 |
#23 |
Why are you running such a low middle point on your V-Curve?
#24 |
I was running a Muti Gov pro at 100 - 80 - 100. I called and spoke to Brian and he said to run 100-65-100.
#25 |
Hmm... even at 65 it should haven't shut TL off. I checked mine night and with my trim at 1/2 (where I always have it) mine didn't hit decay mode until 41% throttle.
#26 |
Updated for recent info on Aux channel assignments changing flying characteristics.
#27 |
I have the Total G with 3 sats and it binds ok, but after 3 or 4 flights (re-fueling and switching off/on) it loses the bind resulting in loss of control and costing me lots of heli coupons.
Any one had this? Any one know of a cure? Never had this with Futaba. |
