Old 09-21-2010, 11:29 PM   #1
rollinolin
Default silicone grease?
the LHS didnt have any silicone grease so i went to auto parts store and they didnt have any either. They did have white lithium grease. i got some...will it be ok to use to lube the metal to metal parts and the fuel tube dampners?
rollinolin is offline        Reply With Quote
Old 09-22-2010, 12:00 AM   #2
Cailid
I use this on all my helis. Works great. http://nexgenhobby.com/index.php?mai...oducts_id=3610
If the brain were so simple we could understand it, we would be so simple we couldn't.
Lyall Watson.
Cailid is offline        Reply With Quote
Old 09-22-2010, 12:10 AM   #3
AzChopp3r
Pure silicone grease can be had from any ace hardware. Just go to the plumbing section and ask for it. Comes in a small jar or tube. waterproof and good to 450 degrees. works good for feathering shaft, orings, dampeners, metal to metal, use sparingly.
Otherwise I use Tri-Flow pure sinthetic grease
SR120, MCX2, Trex500 CF, Blade 400 ,Trex450XL, Outrage 550. Raptor 30 V2 OS37
Raptor 90SE, OS91 Max SZH (sick heli)
AMA# 950209 White Mountain Bald Eagle Squadron
Jesus is Lord Happy Flying
AzChopp3r is offline        Reply With Quote
Old 09-22-2010, 12:13 AM   #4
koolkrabber47
Default not exactly a professional......
Hello rollin.......while i'm not a professional on grease types 101, i will say to be careful switching greases, especially greases from the auto parts v/s hobby shop........I used to be a mechanic for our school district, many years ago.......Some greases are chemically universal and can be used in many, many applications.....other greases have specific applications......instead of getting into every grease available from the auto parts, i'm just gonna say that some greases, like lithium based grease, are made to penetrate the metal in areas like brakes and wheel bearings on autos, where a heavy rain might actually wash the grease out of the wheel bearings.....lithium-based guarantees that some grease, mainly the grease that penetrated the metal, would still protect the metal, temporarily.......make sense??? Kinda???.......if you use these metal penetrating automotive greases on RC Heli's and Planes, they might actually break down the plastic parts and that could prove to be costly as well as catastrophic and dangerous.......Also, for your reference silicone is another word for plastic and a silicone based grease is therefore safe for plastics.....heres a very helpful hint......silicone grease is marketed under several different names and for several different applications and the actual word "silicone" is not alway's clearly posted on the label.......the most logical reason for this is, if you knew, silicone, is silicone, is silicone, you wouldn't go to the hobby shop and pay $4-$5 for a one-ounce tube, if you knew you could buy the same thing at say the "craft" store for 99 cents........make sense now,rollin'........I can tell you for a fact, that at the auto parts store you can buy the same "silicone" grease, it's marketed as "dielectric" grease, it is used to create seperation of the various electronic parts, under the distributor cap, inside the engine compartment......ask for it at your local auto parts, if you cant find it anywhere else.......sorry for the long response......hope this helps......thanx for posting........KOOLKRABBER47........
koolkrabber47 is offline        Reply With Quote
Old 09-22-2010, 12:28 AM   #5
gfdimopo
Default lithium grase to servos?
I use lithium grase yellow for my HXT 900 servos! I have to stop using it?
gfdimopo is offline        Reply With Quote
Old 09-22-2010, 12:30 AM   #6
rollinolin
but i need silicone grease for the orings....silicone spray wont work? would rite aid have silicone grease? any one have some brand names i can look for sense the word silicone isnt always on the container?
Old 09-22-2010, 01:04 AM   #7
koolkrabber47
Default Exactly my point,rollin'......
Exactly my point,rollin'........Silicone grease is made from plastic and is consistantly used for protecting plastic parts and most gaskets and O-Rings,especially on automobiles......A good substitute for your O-Rings would be good ol' vasiline, as long as the O-Ring is not near a heat source.......if the O-Ring is near a heat source, the vasiline will melt and run out.......if your not near an obvious heat source and using the grease as more of a sealer/filler, than vasiline would be more than adaquate........We used to use vasiline on the O-Rings, on automobiles, all the time and on all the O-Rings for the plumbing around the house for 30 yrs.........BTW, silicone spray will not work.....it is too thin and will "run-out" also.......another down side to spray silicone is it attracts a lot of dust like say WD40 would........KOOLKRABBER47........
Old 09-22-2010, 09:58 AM   #8
Cailid
Here's some good reading on types of grease to use.
http://www.helifreak.com/showthread.php?t=156157
Lyall Watson.
Old 09-22-2010, 10:09 AM   #9
AzChopp3r
As I said before, any ace hardware store and for that matter any store with a decent plumbing section like lowes, home depot, true value will have pure silicone grease. Its where I get it and its pure silicone.
Old 09-22-2010, 10:15 AM   #10
koolkrabber47
Default Thank You,Cailid.....
[QUOTE=Cailid;2351828]Here's some good reading on types of grease to use.
http://www.helifreak.com/showthread.php?t=156157[/QUOTE
Thank You for posting,Cailid......I couldn't have said it better myself.....Careful with the Lithium-Based Grease, Gentlemen and keep those difficult questions coming, most likely somebody here on HeliFreak will be able to answer them for you.......It just takes a little time to spot the thread,Have Patience.......KOOLKRABBER47.......
Old 09-22-2010, 11:50 AM   #11
lenrev
I just got some from Lowes. Any place that sells plumbing supplies, specifically replacement O-rings and such for faucets, should have it.
Len N9IJ
Blade 400 (Nue DS450's cyclic, S9257 and GY520, CC Phoenix 35 ESC, SportBEC, stock mechanics), Corona 120, Blade mSR, mCPx, and Honey Bee CP Phoenix 3.0
lenrev is offline        Reply With Quote
Old 09-22-2010, 12:40 PM   #12
Capt.Chip
Here's what I use, bought it at a fishing tackle store @ 20 years ago. It's all they use on reels. It's a silicone based synthetic dielectric.
http://www.acehardware.com/product/i...LAID=323881544
Blade 400 3D, 3-HS65MG, GY520, S9257, Traxxas Y on "Heads Up RC" 3 amp BEC, Stealth CF Blades, 2200 25C, T-Rex 500 LG, Phoenix Sim.,
DX6I, DX8, Blade MSR MCPX V2
TRex 600 ESP
AR 7000, DS610's cyclic, Quark gyro & DS620 on tail
Capt.Chip is offline        Reply With Quote
Old 09-22-2010, 09:33 PM   #13
rollinolin
i ended up getting this
http://www.gunk.com/CAT_GR2.asp
i dont recomend supergluing head parts due to imminent failure
i learned that lesson the hard way today....
where can i buy a good aluminum head and carbon blades for my blade SR....(same source if possible)?
Old 09-22-2010, 09:56 PM   #14
koolkrabber47
Default Excellent choice,Rollin'........
That grease will work just fine........Very good price,too.......Another fine job, done by your fellow HF'ers...................KOOLKRABBER47... ......
Old 09-24-2010, 10:13 AM   #15
crashmore
Silicone grease is in the plumbing section of True Value too. They sell it for lubing o-rings on faucets.
crashmore is offline        Reply With Quote
Old 09-24-2010, 10:44 AM   #16
koolkrabber47
Default Ditto, Ditto, Ditto........
Yup.....That's what i said in Post #7........Been using it for plumbing for 30 yrs.........Thank you for posting, Crash.......Problem Solved???.........KOOLKRABBER47
