Old 09-22-2010, 02:30 AM   #1
foom_xiong
Default How to increase flight time
Hello Helifreak members, I would like to know how to get more flight time out of my bird. Currently, I am only getting about 2 minutes of flight. On my bird, I have a Scorpion motor HKII-2221-6 with a Scorpion 55A ESC thats running a 12T pinion gear; the head speed, last I checked before decreasing my throttle, was at 3500rpm. In one of Finless video, he mentioned that by dropping to a lower teeth pinion gear, flight time might increase. If so, how much? Are there other possible solutions? Any input in helping resolve this issue will be appreciated... Thnx
foom_xiong is offline        Reply With Quote
Old 09-22-2010, 04:14 PM   #2
E-fanatic
I am running a -8 scorpion and getting 5 mins out of it with a 13 tooth pinion and a 3300rpm head speed(no I am not govened). This is useing 3s 2200 25C turnigy nano batteries. There are a few on here getting 4+ mins govenerd at 3200rpms
: HKGT450pro
:Align 450 pro, hs65mg cyclic servos, align 450M motor, quark gyro, outrage os7654T servo, Ice lite 50, Align CF blades
:3dhs planes, 42 and 51 inch slicks,and 72in Extra 330 SC
E-fanatic is offline        Reply With Quote
Old 09-22-2010, 09:12 PM   #3
Future1
I run the 2221-6 on an 11t pinion and get 3.5mins for about 80% of the battery. 2221-6 is not the motor to use if you want longer flight times (though dropping to 11t will help). 2221-8 will get you longer flight times, but it depends if you want your heli to be ballistic stay with the -6, if you want longer flight times go with -8 on13t or lower the pinion.
Future1 is offline        Reply With Quote
Old 09-22-2010, 11:34 PM   #4
foom_xiong
I have just installed the 11T pinion gear today and I agree with you; my flight time is at 3.5 minutes. Thank you for responding to my thread.
Old 09-23-2010, 01:33 AM   #5
sarpilot
-8 will get you 4, maybe 4:30 governed at 3200 depending on your batteries....
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote
Old 09-23-2010, 03:52 AM   #6
Viet-Lama
Im thinking your lipos are duff
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 09-23-2010, 04:21 AM   #7
sarpilot
Is that like shoeshine man at the airport talk? What do you mean exactly?
Old 09-23-2010, 06:35 AM   #8
helidude71
Reduced headspeed will give you increased flight time.
I get 6:00 min. from a 2200 / 35C pack.
No hard 3D, just n00b sports flying.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 09-23-2010, 12:35 PM   #9
SQRT(-2)
Is the speed controller overheating and shutting down? I have had that happen. Are the batteries in good condition?
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote
Old 09-23-2010, 07:45 PM   #10
freperry
Same here, 5 min with-8 scorpion and 2200 battery.
freperry is offline        Reply With Quote
Old 09-24-2010, 08:57 PM   #11
Mystic3D
6 minutes 1000 Mah Consumed
Sport/Mild 3D
Neu 1107/2Y , 11T, Jazz 40-6-18, 4S 1800 40C packs, 3200 RPM
Setup is cool to the touch even on 95 deg days.
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote
Old 09-27-2010, 01:48 PM   #12
darmie
No 3d. I use an 11pinion
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Now over 10mins. I can get up to 13mins, before the lipo alarm goes beeping..
So, I set the radio to a 10min countdown.
Trex 500 3g with tracx rotor head. hs-5245mg cyclic futaba s9650 tail / Trex 600N os50 max s9405 cyclic gy520 gyro ds620 on tail, powered by align 2n1.
darmie is offline        Reply With Quote
Old 09-29-2010, 10:55 PM   #13
goldslinger
Sport/Mild 3D
My setup is almost identical and so are the times. Unless You are doing tic tocs, You don't need screaming headspeeds. Your batts, bearings, etc. will last longer, too. The Jazz governor is magical. I'm running a 80% flat throttle on it.
Gary
T-REX 450SE V2
JAZZ 40-6-18, AR7000, NEU 1107H/2Y, 14 tooth Steel Pinion. Hi-Tech 65MG on Cyclic. DS3500G on Tail; SPARTAN 760 Gyro. BEAM E-4 Tail & Swash.
"The Beatings Will Continue Until Morale Improves."
goldslinger is offline        Reply With Quote
