Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 09-23-2010, 05:02 PM   #1
d3sbo
Default Total G odd when using hard +- collective pitch
right have got the stops working good now
but have seen something else i don't like which it if i fly straight and level fast then i add hard + collective say to climb the nose off the hell bounces up and if i use hard - collective to descend the nose bounces down
some pointers would be good thanks
yes i am asking all groups the same thing
2 x Blade MCPX,stock & duel Brushless
Trex 250FBL,BeastX,Scorpion,Trex 450,Scorpion,4s,Jazz esc,Trex 500FBL,3GX V3.1,5s,Scorpion
Avant, Kasama head,OS 91 OMI,XeroG Raptor,Total G,Outrage Head
Trex 600 EFL Pro super combo,BeastX
d3sbo is offline        Reply With Quote
Old 09-23-2010, 06:40 PM   #2
nwmtech
I do believe Curtis is aware of the issue and it will be addressed in the firmware update coming up soon.
nwmtech is offline        Reply With Quote
Old 09-24-2010, 01:26 PM   #3
Buzzin Brian
The unit mounted soft can cause that. How is the unit mounted?
Brian
Buzzin Brian is offline        Reply With Quote
Old 09-24-2010, 04:12 PM   #4
d3sbo
it is on 2 by 2 bits off double sided foam like the instructions say but i do have a Velcro strap around it
Old 09-24-2010, 05:12 PM   #5
Buzzin Brian
2 pieces thick? If so, that is to soft. The instructions are wrong in the regard. There only needs to be 1 layer of tape, and if the model is not a vibration maker, strap it down tight for best results.
Brian
Old 09-24-2010, 06:02 PM   #6
d3sbo
i will give it ago and let you know how i get on ill have to get some more tape
Old 10-01-2010, 10:29 PM   #7
Sam2b
Please ensure your CG is perfect by holding the heli by the grips vertically.
_Sam B_
Team MSH USA, Prtos Max v2 ● Brain Flybarless System ● Xpert servos ● Cyclone Blades ● ProgressiveRC ● VoltMagic ● Ecalc
RCHN Citizen 662
Sam2b is offline        Reply With Quote
Old 10-02-2010, 07:28 AM   #8
d3sbo
mine is tail heavy but not by much but will try thanks
Old 10-13-2010, 09:54 AM   #9
Dr.Phil
d3sbo, just wondering....
did it help to change to one layer of tape?
Dr.Phil is offline        Reply With Quote
Old 04-14-2011, 03:44 PM   #10
d3sbo
still having same problems with v2 software and one layer off mounting tape
HELP
