| CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support |
Any users out there experiencing problems when using the unit with Spektrum satelites?
No. I've got 3 satellites on mine and everything's smooth.
WWBD? |
yes had some thing like 2 9 99 in the hit counter thing so i changed one rx the one that was flashing and went up to 3
2 x Blade MCPX,stock & duel Brushless Trex 250FBL,BeastX,Scorpion,Trex 450,Scorpion,4s,Jazz esc,Trex 500FBL,3GX V3.1,5s,Scorpion Avant, Kasama head,OS 91 OMI,XeroG Raptor,Total G,Outrage Head Trex 600 EFL Pro super combo,BeastX |
Make sure you bind with all 3 satellites (or however many you choose to use) plugged in to the Total-G. Also ensure that if you turn power off from your Total-G that you turn your transmitter off and then back on before reapplying power to the Total-G.
WWBD? |
I also experienced the same thing. Complete loss of stick input to the helicopter. I had nothing as well. Properly bound, power off and on both radio and unit, etc.. Running on all satellites as well.
Loss Hatori pipe, cracked engine case, blades, etc..
It is better to be thought of as a fool than to open your mouth and remove all doubt ... |
#6 |
#7 | |
How many satellites? Redundant power supply? Failsafe style switch? Regulator? Did you check the log after the crash? |
#8 |
I was running A123 straight. 6v.. I was using a heavy duty switch to turn it on, but that was it. Unfortunately, when the crash happened, nose down in the ground, the baterry was ejected. From my understanding the misses and counts will clear when you cycle the unit. So I could not look at any misses. No redundant power supply. never really have used one.
#9 |
Ok, just checking. You're correct in that there would be no way to truly find out what happened then. There have just been so few communications related complaints with the totalg it's hard to imagine that was the problem although anything is possible. That's why I'm so anal about at least two power leads into the unit, 3 satellites (on a larger heli), and a failsafe style switch. If i lose stick input then I want to be 100% sure it was the unit that failed and not that I was losing power input. Sorry to hear about the crash man. That really sucks.
#10 |
.... NOBAR!!!!
Fury55 NIB Furion6 CGY750 fbl helicopter-Frenzy CGY750 fbl nitro-Frenzy fbl NOBAR90 and a clone450NOBAR Burning Nitro and Electrons simultaneously |
#11 |
Seriously dude.... don't come in here and hijack a good thread with your nobar
please. |
#12 |
nwmtech....it's all good. Heli-cuzz is one of my good local flying buddies. He likes givin me a hard time about the stab systems. lol it's all in good fun.
On a sidenote I will be callling Cy ent. in the am to discuss my problem. Will post and update as soon as I know more. |
#13 |
Cool. Let us know how it turns out.
#14 |
Any word yet on CYE!!!!! getting back to you ????
#15 |
Still not feeling well.:o So a late call to them this afternoon and tech support was out for the day. Will make sure I calll earlier in the Am on Wed.
#16 |
Spoke with Brian this AM. He took plenty of time and discussed my concerns with me, also explained the reasoning behind there mode of failsafe. Waiting for a RMA# and off my unit goes for testing.
