Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Ufly
Ufly Walkera Ufly Helicopter Support
Closed Thread
Old 09-26-2010, 07:53 AM   #1
arwins
Default Flybar upgrade for UFLYS
The stock flybar gets bent easily, so i was looking for an upgrade, and i think i read something about using parts from axe cp. Can someone help me on this? Thanks in adv.
arwins is offline
Old 09-30-2010, 01:29 PM   #2
3d-wanna-b
You can use any 450 sized heli flybar and paddles, you can also use the axe cp paddles...
Beating the air into submission!!!!
3d-wanna-b is offline
Old 10-28-2010, 04:16 PM   #3
NCflyer
You can use any 2mm steel flybar and cut it down to approx 165mm. In my case I used the upper stabilizer off an Walkera LM3, removed the plastic and cut/file to suit. Add some Walkera HM59dq paddles and Balance blocks(and a screw set as the balance blocks come minus the grubs). The balance blocks need to be drilled out a to 2mm. A simpler solution I guess would be to locate a 450 with 2mm flybar. Flys ok and the extra weight adds a little to its stability
Mick
Uploaded with ImageShack.us
NCflyer is offline
Old 12-27-2010, 02:48 PM   #4
arwins
lol i screwed it up by taking cf axe cp paddles and forcing it to fit the trex flybar -.- damn. 30 bucks gone
arwins is offline
Old 12-28-2010, 09:50 AM   #5
3d-wanna-b
How did it mess up the paddles? I'm using a 450 sized fly bar with axe cp paddles and they screwed right on no problems..
Old 12-29-2010, 02:42 AM   #6
arwins
Well those paddles werent made for the flybar, so it made a bulge on the flybar and it wasnt straight as i screwed it in
...and then i saw those bloody paddles just without the axe cp name made to fit for the flybar going for 2 bucks.
arwins is offline
Old 02-27-2011, 05:35 PM   #7
magicmarty
i believe i read somewhere that the tail boom struts can be used as replacement flybars cause they are the same dia and length....
magicmarty is offline
Closed Thread
