| FMA/Revolectrix Product Support FMA/Revolectrix Factory Product Support |
Hi, I need help... I maidened my Trex 600 3G without CPii and had no problems mechanically or electrically. I installed the CPii, I had a few problems that got ironed out thanks to Night and Howard. Anyway went to maiden with CPii on Sunday, everything seemed OK, CPii was off with 0 trim, and at about 3 ft got a brown out and the heli slowly dropped to the ground and landed on skids with no damage. While we were looking at the heli and wondering WTF, the AR7000 and satellite started flashing lights once and while showng brown outs. The only thing that changed was the addition of the CPii, could the CPii have anything to do with brown out. The Rx battery was fully charged. The guys at the field (non believers) say get rid of CPii its gotta be the problem. I dont want to get rid of it. Please help. Terry
Goblin, SK720 / TREX 450 Sport FBL SK720 TREX 600 3G, CPii MSR / mCPX brushless/YAK / McFoamy |
Are you using an ESC BEC or separate BEC and if so what current rating. You have to take account that the current load of FBL servos is higher as well as the 3G controller and the CPII avionics computer. Your BEC should be rated 8-10A for this setup std 3-5A would be very borderline as you might have experienced.
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM. Blade400-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor. |
Need to check your total current draw, if your using an external BEC or voltage regulator it may well not have enough ponies to drive everything at once, or if your using a flight pack it also may not be enough
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
Thanks guys, I should have explaineds what i'm using. Trex 600 3G nitro, stock 2 in 1 regulator, align 610 servos on cyclic, 620 on throttle and 650 on the tail. Using a 2S 2200 mAh battery to power it up. How do I know if I dont have enough power, sorry Im a confused noob.
The 3G has been noted to have a power distribution issue.
I'm running the 3G CPII combo on my 650 stretch 610's on cyclic and S9256 on the tail with my Spartan ds760. AR7100 Rx with dual remote Sats Using the Spektrum VR6010 rated @ 10 amps with an OUTRAGE 2S 2500 flight pack to power all the electronics, been working like a dream. Your heli in stock setup should have enough power to run the electronics but might be at it's max, add the CPII and it could be pushing your 2 in 1 over the edge
#6 |
The Align 2 in 1 is rated @5.8V 6A. I have used it on my NSP and now that it is converted to electric still using it. There are threads and threads of 2 in 1 failures and generally it is first to be blamed in cases as such. So it can be developing a fault under load and you should be watching it closely.
I guess it is time to either replace it or search for a good alternative. ElyQ 10A /100A pk 2 Output Prog Voltage Regulator or Fromco Arizona http://www.fromeco.org/products/02frariz-200/
#7 |
Hi Pril, If I get that Arizona, I assume I would then need a swichglow or some other type of glow system. Is there anything else I would need. Thanks again for the help.
#8 |
Either get a Switchglow or leave the 2 in 1 there just for the glow function. As result of this conversation I decided also to replace my 2 in 1 by a CC Pro BEC.
#9 |
Hi, I upgraded to a 7100r Rx and a switch glow (lasted 1 day before failing). I replaced the defective switchglow and put back in the 2in1 for glow purposes only. I had some spare time and looked at the switchglo to determine why it doesnt work, what I found is that the 7100r is putting out full RX pack voltage on the 5.0V side of the 7100R. I have the cyclic servos on the high voltage side, and the rudder and throttle on the 5.0v side. When I unhook the CPii from Aux2 which is on the 5v side of Rx, the output voltage on the 5v side is now at the proper 5V. Is it possble that the voltage from the cyclic side of the Rx somehow feeds back through the CPii and boosts up the 5v side. I also have a 3G hooked up as well in the system. BTW the heli flies great and the CPii as well as everything besides the voltage problem works great. I could use some help here.Thanks in advance. Terry
#10 |
Need more info on how things are routed but if the voltage is feeding back from CPII through to AUX2 you need to snip the red wire (center) on that cable and I think you should be good to go. To not be destructive on the CPII looms, use an extension cable on Aux2 to perform this exercise.
#11 |
Thanks Pril. I wish I would have thought of cutting extensions before I snipped the throttle and switchglo power leads, duh. At that time I thought the 7100 was causing the problem with high voltage on all the outputs except the rudder, so I was gonna power the throttle and switchglo off that output. This us when I realized the output on that was high voltage as soon as CPii was on. Another question. Does the CPii not get powered up through the on/off lead that goes to Aux2, or is it just using the signal from that output to turn it on?
#12 |
I can only assume that the internal power rail is linked to all center pins on the external connectors and that the highest power fed on any will be present on all.
#13 |
I assume you are correct Pril, I will cut it tonite and measure voltage
#14 |
Two 600Ns here running from stock 2-in-1 BECs (5.8V) for a year with CPII and no issues whatsoever. Both are FB, though, so cyclic servo load is lower, but the 2-in-1 BECs are powering everything, the whole power distribution is as follows:
2-in-1 -> AR8000 with throttle and rudder servos + TM1000 -> CPII -> cyclic servos
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
