Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 10-06-2008, 07:28 AM   #21
Azzurra
Hi,
after testing 5 systems in 9 months, I finally found one that works really well! But first let me comment the setups I had:
1. Original: 600XL & Align 75A ESC: cheap; power OK, but governor not usable.
2. Upgraded to Kontronik Jazz 80-6-18 ESC: Good governor but 600XL got raher hot now.
3. Upgrade to Kontronik Tango 45-10 motor: Good overall Power, but now my 6s packs smoked.
4. Upgrade to 10s setup with Kontronik Tango 45-07 motor and Jazz 55-10 ESC: More power, very consistent head speed, but the Tango got rather hot; finally bonging of a magnet failed, causing the motor to block. The motor was repaired by Kontronik for no charge(!!!)
5. Upgrade(?) to NEU 1515-2Y/F: A lot of headspeed, but bogging as well. Heli felt heavy when flying and ESC shut down due to overtemperature. Bad bearings. Maybe this was the wong NEU for 10s.
And now finally
600CF; TT, FULL BLING
Radix 600
9252 on Swash; 401 & 9254 on Tail
2 X 5s 3200 Polyquest and 2 X 5s 3700 SLS ZX Packs.
CSM CL1 eCCPM on Board
5A UBEC
KONTRONIK Jazz 55-10 ESC
PLETTENBERG Orbit 30-12 Heli Expert Motor:
Weight 3390 & 3480 Grammes, depending on battery pack
17 T pinion
Throttle at 52% and 65% governored.
Gyro Gain at 43% and 40%
Comments:
The bird feels lightweight again and flies very well. I have two head speeds: 1950 and 2150; the system can keep them very consistently. The temperatures after 5 to 6 minutes 40plus Style 3D is very moderate: 35° Centigrade for motor and ESC and 35° for my bigger packs and 40° for the 3200 mAh. I think; I will stay with this setup except I’ll get rid of my flybar in the next months and swap to a VSTABI system.
T-Rex 600 CF | VBar |TT|Plettenberg 30-12HE|JAZZ55-10-32|3X9252|9254|FF-6, FASST|Radix600|SLS3700ZX 10s packs
Azzurra is offline        Reply With Quote
Old 02-20-2009, 03:50 AM   #22
hondahirny
Default Scorpion 4025-890 on 10S 3300mAh
Motor: Scorpion 4025-890
Battery: 2 x 5S 3300 Zippy-H from hobbycity
ESC: Castle Creations 85HV
Power: Enough
Current in hover is about 25 amps at 2200 RPM headspeed. Peak currents running +/- 11deg of collective produce about 85-90 amps. I found that heavy collective use kept voltage above 3.3V per cell and that headspeed didn't go much below 2000RPM. Power peaks regularly hit around 3000W.
Flight time is set at 4:00 minutes and i put back in about 2400 into the packs or 73%. Packs come down warm, but not abnormally hot. They run cooler than my old 6S setup.
Ex heli pilot, now trolling HF as a glider pilot
hondahirny is offline        Reply With Quote
Old 08-12-2009, 06:35 PM   #23
Ruby
Default what about duration?
I been browsing thru the posts. Is there any setup that will give you duration. four minutes is not enough. I will also like to see pictures or a how to put all this together (hint hint Bob). I'm back in the U.S. and flying sites are all over. I love my T-Rex 600 but four minutes is just a warm-up. I flown gliders way longer than that. Again guys, someone guide me or post a link. I'll settle for 10 minutes of flight. After going electric, don't miss the clean up or the noise or better yet the engine tuning.
like planks but love rotors
Ruby is offline        Reply With Quote
Old 08-16-2009, 10:37 PM   #24
dieselracer
My set-up
600ESP
Neu Motor 1915/1y W/ 13t
CC85hv
611 Gyro
Hp heli aluminum Frame, horizontal and Long vertical fin
Align 600D blades
Microheli 700 CNC main gear.
dieselracer is offline        Reply With Quote
Old 08-26-2009, 10:11 AM   #25
ov10mech
That thing is a missile. What headspeed?
Originally Posted by dieselracer View Post
My set-up
600ESP
CC85hv
611 Gyro
Align 600D blades
ov10mech is offline        Reply With Quote
Old 08-26-2009, 11:09 PM   #26
dieselracer
2520 at centerstick.
Old 08-27-2009, 02:09 PM   #27
ov10mech
Thats some serious HS for a 50 size
Old 09-07-2009, 08:23 AM   #28
OTA
Hey guys ! This is not the "Discussion" thread. Please read the first post one more time please
T-Rex 650 CF / Scorpion 4025-630, 12S
Jive 80+HV,2 x TP 3300 6S V2, Radix 710SB,Super Stubz,Futaba 9451,Spartan DS760/BLS251.Quick UK swash and tail
T-Rex 700N, OS 91HZ, Hatori 939, Radix 710SB, BLS 451, 9254 for throttle, Spartan DS760/BLS251, Quick UK tail,
OTA is offline        Reply With Quote
Old 01-25-2010, 02:22 PM   #29
Rogman88
Default Good simple setup
My setup that works well and uses only one 6S battery.
Trex 600 ESP with stock everything.
Stock align regulator with 1900mah 2S lipo - gets around 6-9 flights between charges.
Align 610 cyclic servos - very fast and powerful for the price
Gy 611+9256 combo - rock solid at 400$
K&B tail rotors - good
Radix 600 stick bangers - balanced out of the pack and plenty of "Pop"
Scorpion 4025-1000kv motor on 15T pinion - good power but not like others I've seen.
CC 85HV - set to govornor mode at 85%, plenty of options and I love the castlelink software. I do need to update though. I have the october release at the moment.
Turnigy 35C 5000mah battery - on 6 cells it gets pretty warm at the end of mild 3D (tic tocks, piros, FAI FFF moves etc.) put back 3800-4000 depending on how crazy I get on the sticks.
Overall Impression: Simple (no series connectors) and easily balance charged on inexpensive 6S battery chargers. It does take almost 2 hours to put back 4000mah on a cheap turnigy 50W that only goes to 2.2A even though you put 5A as the charge rate. Icharger 250W will charge at true 5A and puts in 4000mah in just under an hour
I will be going to 12S though (6S 2p turnigy 3000mah in series) and will charge on parallel at the field and balance charge at home. I'll be selling the scorpion 1100 for 630kv to do this due to fairly warm battery packs and would like to extend the longevity of the packs. I have noticed after 50 flights now that the 35C batts just don't have the "umpffff" that they used to. I would recommend 40-45C setup for anyone wanting to use 6S for harder 3D!
Hope this helps!
Rogman88 is offline        Reply With Quote
Old 03-12-2010, 12:22 PM   #30
morph78
600CF
TorqueTube
new align 600m motor (peaks in 3000w)
CC ICE 100A
610 cyclic
Align 3G FBL
Turnigy 30-40C 790gr 6s
SAB blades
NO Bec, super light (3280gr RTF).
morph78 is offline        Reply With Quote
Old 03-16-2010, 08:14 AM   #31
mattrex
Talking HV setup
600 CF
4025-630
CC85HV
Turnigy 6s 40c 3000mAh x2
15/188
going to 16/188 to give governor more head room
Head speed 2150 @ 0 pitch 70% throttle
Flight time 4 minutes for this i put back 1600-1700mAh
using about 400mAh per minute.
Motor comes down warm, batteries are just warm,ESC ambient.
Mild 3D, lots of fast forward flight.
mattrex is offline        Reply With Quote
Old 07-15-2010, 03:41 AM   #32
livninlv
i dont understand how to program my esc with the helical gears. i have a 13/188 and my castle link says 1600 in to high. i checked the kv on your motor and its pretty close to mine(890) but i cant get no ware close to what i want. can you tell me what im doing wrong?, thanks got this from post#2
T-REX600-2 configuration.
- Weight 3,48kg / 6 pound 17 oz
- FlightPower EVO 20 10S 3300ma
- Kontronic Tango 45-08
- Align receiver akku
- 13/188T helical gear
- 0 pitch 100% Rotor RPM = 2080 RPM
- 601 Gyro
- Fut 9252 servo´s
- Tail blades = Align
- Main blades = 600mm TT blades
Motor temp before/after = 9C48F/25C77F
Battery temp before/after = 14C57F/30C86F
this is my set up
scorpion 890kv
cc ice 100 esc
13/188 helical gears
2x4s 4500, 30c
600mm blades
i;m trying to run it in gov. mode but anything over 1600 is to fast.i'm thinking i need to go to a 16 to get the head speed i want but i cant find one for a 5mm shaft. anyways can anyone help me, thanks
livninlv is offline        Reply With Quote
Old 12-12-2010, 07:09 PM   #33
nairbg
Originally Posted by mattrex View Post
600 CF
4025-630
CC85HV
15/188
How do you get twice the HS from this 6S - 630kv 15/88 setup than the 1050 rpm that the RediHeli calculator figures it would be?
nairbg is offline        Reply With Quote
Old 12-12-2010, 10:29 PM   #34
balance_mind
It' a 12s setup
balance_mind is offline        Reply With Quote
Old 12-13-2010, 01:43 PM   #35
nairbg
Originally Posted by balance_mind View Post
It' a 12s setup
Doh!
Old 01-05-2011, 08:56 PM   #36
teshreve
This thread is redundant.
I vote it be unstickied.
teshreve is online now        Reply With Quote
