I ordered some of that braided sleeving today to dress up/protect the wiring in my Rex450 project.
My question is this: Do you use heat shrink tubing to secure it on the ends? It's not clear from the Finless vid, where he shows Ricks excellent SE. Should I get a crimp tool to shorten my servo/gyro wires or solder them? thanks as always, joe |
oooh dressing up the wires..oh my that takes me back to my Action Man days...Laura Ashley looks nice.....pastel and forrest always go well i think
Ooops ermm to coin a phrase 'Now i do believe you didnt want to do that' Confused childhood
T-Rex 450 CCPM with metal tail rotor (miles more stable)... T-Rex 450XL HDE with lots of yummy upgrades... 'Occifer i swear to Drunk i'm not God' |
Im using Century Heli Mesh products and i just use a small zip tie to secure the ends. Seems to work good for me!
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Mark, that's too funny Good job mate!
#5 | |
Ok on serious side....i loop wires around on themselves and tie wrap them on the frame....behind struts etc... Please excuse pics...but you get general idea.. Hope this helps Mark
#6 |
Hi all,
I use shrink tubing to dress the ends of the braid. If your going to the trouble of dressing your wires, then definitely shorten them, where appropriate. check out hansen hobbies for crimpers and contacts for a decent price! Cheers, Leslie
If you can't stand behind our troops, please feel free to stand in front of them. |
#7 |
I hope that this helps; please follow this link and it will be explained. Also you can order from them direct, by the foot or yard.
Seaknight Semper Fi http://cableorganizer.com/terminate-sleeving/ |
#8 |
here is a page I made up to show how to install the wrap.
http://www.big-alshobbysupply.com/wire_prot_inst.htm
--------------------- Alan 'Big Al' Warfield --------------------- |
#9 |
Yes, you need heat shrink on the ends or the wrap can unravel and make things look WORSE.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
#10 |
Actually, you can "seal" the ends of the braid with CAREFUL application of a soldering iron tip.
I like the heat shrink method myself. Pop the pins out of the connector, slide shrink tube over the wire, stuff the wires through the braid, stick on another piece of shrink tube and shrink it all up. Stuff the pins back in the connector and you're done.
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 | |
#12 |
I did it the hard way (typical). You can get the wires though WITH the connectors still on.
#13 |
drphoto, I used heatshrink to keep the ends tidy and to 'splice' the servo wires into the loom. The servo wires were adjusted for length then had new pins and plugs crimped on. Works for me.
T Rex SE, HS65MG's, 401 with 9650 etc all put together and learning to hover with Bob's video help and the great Phoenix sim. |
