Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 10-06-2010, 09:39 AM   #1
RĒzĒ
Default How-To: Piro Flips with Video
One absolute prerequisite I should mention before you start any of this is you should already be very comfortable with inverted hovering. If you can't invert hover without making mistakes in all orientations keep working on that and come back to this later.
Start with half flips. Start learning a half flip by doing the elevator and rudder movements seperately at first.
  1. Start upright tail in.
  2. Give a little positive pitch to keep the heli from falling
  3. Push forward until the nose is pointing straight down.
  4. Stop pushing forward then give left rudder until the tail is straight down.
  5. Pull back on the stick to level out. You will be inverted with the tail facing you.
  6. Stop there and regain control if you are a little off.
Keep doing this until you are comfortable. Gradually work the sticks in unison to smooth it out into a single roll/flip. Ultimately you want to start by pushing forward and giving left rudder at the same time. Then you should roll the cyclic stick clockwise until it gets to the 6 o'clock position. Timed right you will get a smooth roll and end with the heli inverted tail in.
Once tail in inverted you pull back on the stick and continue to give left rudder (same rudder all the time). You will roll the cyclic stick smoothly clockwise from the 6 o'clock position back to the 12 o'clock position. Again this should end up being a continuous smooth roll. You will end up where you started upright and tail in.
Practice each half slowly and eventually you can start to put them together to do a full half piro flip.
Full Piro Flips
You should be completely comfortable and dead on with half piros before considering upgrading to full piros. You should also be proficient in flips and rolls that end with the heli nose in inverted. I.E. practice nose in rolls and flips making sure you can stop halfway while still in control...
  1. Start upright tail in again.
  2. This time you will apply forward cyclic and left rudder again but you will need to give more left then with a half flip because you want a full piro rotation.
  3. Stir the cyclic clockwise as before, but this time follow the tail completely around and stir in a complete circle. It's important to always stir with the speed of the tail. Watch the tail go around and move the stick around as it moves. It's a timing thing and the more you do it the sooner it will "click"
  4. If timed right and all goes well you will end up inverted nose in.
  5. Make sure to pause here and regain control before trying to flip back out.
  6. When starting out just reset and start over at this point. Keep repeating this until you can get the heli to stop and correctly be at the inverted nose in position. Without being able to do this properly you will never get a clean piro flip.
  7. The beauty here is you just do the exact same movements to get back to upright tail in again. Repeat this as many times as it takes to start to get this to look and feel right. This part was always easier for me because you end up upright again which was easier for me to regain full control of in case I'm a little off on the timing.
The important thing here is to stop at each half when you are learning. Do not try to do full flips when you are starting out. They will be very sloppy at best and you won't know why. Also doing one half at a time will make learning the timing of the stir with the tail much much easier. Work on each half slowly and dont start going again until you are back in control and the heli is centered and back in front of you if you drifted away. When you are ready you can start to link the two halfs together to become a seamless full flip.
As always if you are new to this stuff definately only try this on a sim until you get a good idea of what you are doing. You are nearly guaranteed to crash doing this stuff.
Anyways thats how I've been learning and I've only needed a little over a month to get this mostly down. So I hope this is useful for some people that are looking to learn.
RĒzĒ is offline        Reply With Quote
Old 10-07-2010, 10:33 AM   #2
D Grade
Thank you as always for this stuff, it really helps. This is my next step in learning and Im looking forward to learning the piro flip. This will no doubly help!
T-Rex 700LE x2 T-Rex 600LE x2T-Rex 600ESP T-Rex 500ESP x2 ElyQ Vision 50 - OS55, B320
Flown via DX7
D Grade is offline        Reply With Quote
Old 10-08-2010, 02:04 AM   #3
Lottomunch
I have wanted to try this for years and have struggled with zero success. I watched people do it and I knew it wasn't THAT hard but I couldn't even figure out how to start the manuever.
I am stoked that after 20 min of following your directions I have pulled off ugly half piro flips on the sim. I'm still a long way out from being able to do them pretty on a real heli but I've got a direction now. Just need to invest the sim time.
Thank you
Thank you
Thank you.
Lottomunch is offline        Reply With Quote
Old 10-11-2010, 06:09 PM   #4
400driver
Thumbs up
superb, best training video I have seen so far.
Many Thanks
400driver is offline        Reply With Quote
Old 10-14-2010, 12:10 AM   #5
helinovice
HI Raza,
In thanks for these wonderful tutorials, is it at all possible to show mode 1 Tx on sim please.
In appreciation,
Vaughan
14MZ
helinovice is offline        Reply With Quote
Old 10-14-2010, 12:44 AM   #6
RĒzĒ
Here's a short vid a while back that shows most of the moves in mode 1.
Old 10-14-2010, 03:01 AM   #7
helinovice
OUTSTANDING!
Very Much Appreciated mate,
You have given hope to me now,
Cheers,
Vaughan
14MZ
Old 10-14-2010, 05:44 AM   #8
Hmateen98
Wow! This is the first time I've seen the maneuver broken down into segments.
With this kind of detailed instructions, it will be easier to understand and pratice the movement.
Great Job
Keep the invalueable videos coming.
Hassan M
2 X 250 SE, 450 SPORT TT upgrade KBBD Paddles & Tail
450 PRO 3G conversion HS5065MG KDE upgrades
500 ESP 3G conversion 550E Stock BeastX,
700E SK720 in building progress
Hmateen98 is offline        Reply With Quote
Old 10-14-2010, 03:11 PM   #9
s0laris
The way i learned them is radically different and may work for you.
Learn to do a piro loop in any direction..
Start to make the loops smaller and smaller.
eventually you are looping it around one "line" and voila the piro flip is born. But this one will look different as the blade plane is going in one direction all the time.
If you can do this one then other variations just come with more practice.
Team Fun / Heli Canada
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote
Old 10-15-2010, 07:56 PM   #10
$teve
Great Video, I was doing half piro flips and didn't even know it, while transitioning from upright to inverted. You've help me put it all together now. Thanks! It seems so simple now.
How are you recording that? Setting up a camera in front of your monitor?
Keep up the great work.
$teve is offline        Reply With Quote
Old 10-15-2010, 09:06 PM   #11
RĒzĒ
i use a program called "fraps" it records the computer screen real time
Old 10-20-2010, 08:01 AM   #12
Spindle
Raza excellent videos This forum and finless's videos r the best here on HF
Spindle is offline        Reply With Quote
Old 11-05-2010, 11:20 AM   #13
Ubi22
Hi there (1st post, go me )
Just been reading and practicing advice on this post and came across some think that really helped and maybe will help others and that is the sim speed, on Phoenix it can be slowed down with the - key, this aloud me to practice at a speed my skill level could handle and as i improved then speed it up with + key. Seem to work for me to get me started although still along way to go !
Great Video very helpful !
Ubi22 is offline        Reply With Quote
Old 03-10-2011, 11:19 AM   #14
RĒzĒ
Video demonstration. Fernando was nice enough to capture this on video. This is me flying my Logo 600 3D explaining piro flips.
Old 03-10-2011, 06:16 PM   #15
Finless
Team Taco VP
Nice teaching job RaZa!
Bob
Old 03-10-2011, 07:32 PM   #16
RĒzĒ
Thank you
Old 03-14-2011, 04:58 PM   #17
kouasupra
I would have to agree with Bob. It's nice to see you actually demonstrating in real life. I like that so much more better then the sim. Much thanks Raza!!
kouasupra is offline        Reply With Quote
Old 03-28-2011, 01:24 AM   #18
CHIEF-X
we need a extra spot on the main page for this kinda stuff so all can get good use of it. its really hard to find videos like this! does anyone else agree!
DX8
COMANCHE TRIBAL MEMBER 4TH GENERATION
PLAN FOR THE WORST, HOPE FOR THE BEST!!!
CHIEF-X is offline        Reply With Quote
Old 04-07-2011, 11:05 AM   #19
IrvingWashington
Had to reply just to say thank you very much for this vids RaZa!
www.losalcotanes.com
IrvingWashington is offline        Reply With Quote
Old 04-07-2011, 11:06 AM   #20
RĒzĒ
