| RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A |
Today I want to talk about Autos. They are one of those deceptive things that at first seems really hard, but then they seem really easy, but to do really good ones, they become really hard again
I want to share what I've recently learned in the last couple of weeks. It boils down to this one simple statement: Even at negative pitch you can pull out of a dive or FFF. I started to notice that if I was flying forward at a decent pace, I could pull up and gain altitude even when I was at zero pitch or even less than zero pitch. This is not an obvious behavior about flying helis. With that knowledge in hand I started practicing and right off the bat I started pulling off some near perfect autos.
So I hope that helps some people. It was definately one of those click moments for me. I always avoided learining autos as I didn't really understand what went into doing one properly. Now that I understand them much better, autos are finally easy again |
+1. Nice write up. I was fortunate and was able to be a bystander at Todd and Matt's flight school this year in Snohomish, WA. I was able to stand behind a buddy of mine taking the class and was quite shocked when Todd told my buddy to auto at midstick (it was a 700). I would never had thought it possible until I saw it with my own two eyes. He never went negative and was able to keep the headspeed up by finding that sweet spot with the angle of attack. Just goes to show that VERY LITTLE negative pitch is needed.
Hmm, are you suggesting not to use positive pitch at all, not even just before touching the skids?
No no. Of course you have to use positive pitch to flare at the end. It was more to point out how little negative pitch is actually needed to keep the headspeed up UNTIL the flare.
Hi nwmtech,
I think whilst flare, we have to keep the blade pitch in negative angle as RaZa says in his instruction. This converts forward momentum into the additional speed for main blade. Once the model stops moving forward, we should have good rotation inertia of blade then use this inertia power to land model in the spot with just enough positive pitch angle. |
#6 |
please post a auto video
#7 | |
#8 |
I was doing autos on reflex with a raptor50 last night and managed to actually pull a few with just negative pitch! At loss of power I pushed the nose down about 45-50 degrees, let the heli gain momentum and the blades were spinning up real fast at about minus 8 pitch, then pulled the heli out of the nose dive and without touching the pitch I was able to land (maybe twice... mostly otherwise I think I would get out with minimal canopy damage). I can't really explain, but it works. I'll try to do a vid tonight, problem is I have reflex 5.0.3 and I don't think it can show stick moves.
When I added positive pitch and flaring at the bottom point, I was able to actually hover for about 5-6 seconds above ground from the energy stored in the blades. By the way Raza, how do you manage autos from vertical nose down? If I cut throttle in that orientation and wait 3-4 seconds before pulling the collective back (assuming that'd be time to realize that I have no juice and react), I can't recover any more from the nose dive.
I am a HeliCoholic! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Fusion50FBL μBeast TRex500FBL μBeast Blade 130X Blade Nano Spektrum DX8 Blade 120SR handbuilt Coastguard AW109 see my avatar For the winter:Reflex XTR
#9 | |
If you nose down at all do it very briefly and high up to give yourself time to level out and spin the blades back up with just a few degrees of negative pitch. Too much negative pitch can actually cause too much load and not spin the blades back up as quick. |
#10 |
Thanks Raza. I thought I was missing an obvious trick, but you pretty much re-enforced what I thought, if I ever lose power nose down and can't pull out immediately, I'm hosed
#11 |
I was able to capture a few vids from Reflex
#12 |
I'm sorry I didn't even see your request. here's my 250 auto video. It's soo much harder to do an auto with a 250. I can do inverted autos on bigger birds. But for the life of me I have trouble with the 250. I know, I know Raza, is going to tell me again, Poor Collective Management. That is why I am here again!!.How's my auto raza? It's harder with the smaller bird! Senone: anyways your video that you requested.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Just how deep does the rabbit hole go? |
#13 |
Raza: I can do indefinate tic tocs now. I am so happy. You taught me how to do tic tocs. Thank you. But my overall flying is crap. I don't even know how to do nose in hover!! Where do i start? Give me some pointers for nose in hover please. The same way you gave me pointers for the aileron tic tocs. I don't need the bigger birds, I know I can master these little birds. Everytime I try to practice "nose in hover" I just end up doing freestyle flying. I don't even know what I am doing!! And in real life, it's the same. I just zip around in the air, like in the video, but only 110% faster. When I really do try to do nose in, I keep getting blade strikes. What am I doing wrong? Where's the "nose in hover" thread? I need your help, please Raza.
#14 |
Team Taco VP
Here is an auto training video I did about 2 years ago.
VIDEO -> Learning to shoot autos on a 450 and showing the sticks (39 Megs) Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
Nice. Goes to show how little neg is really needed. To those that think you need full down stick you can see Bob barley ever went further than a full tick mark below center.
Awesome thanks Bob |
#16 |
Nice Bob, where would we be without those?
So true Raza, with full negative pitch you'll basically fall off the skies until you increase pitch. With just enough negative pitch throughout the entire auto the driving region will continuously provide enough RPM with enough lift for a constant slower decent that allows you position the heli for landing. There are many good articles that talk about blade regions during autorotation and their roles at different pitch, in rchelimag here http://rchelimag.com/pages/howto.php?howto=13&page=4 or on copters here http://www.copters.com/aero/autorotation.html.
#17 | |
As a newbie, there's no way i'll be going near idle-up any time soon. I have a TRex 450 Sport that i've just moved up to from a Honey Bee cp2 and i'm interested in what sort of blade angle is needed for autos. I have my 'normal' mode set up pretty much as per the manual. I used a pitch guage and I wrote down my setup: Zero stick = 0 deg 50% stick = 4 deg 100% stick = 9.5 deg (I kept it conservative as a beginner because I didn't want it to be too much for me to handle, i'll increase it when i'm good enough). I know a couple of real life heli pilots so I could ask them for the full auto-rotation blade theory lecture but in practice, using RC helis, you guys know what's going on. In my early days, I can't help feeling vulnerable - if I have some sort of failure, I really am in the lap of the Gods... but what with volcanos, famines and floods troubling the planet, I don't think my prayers would get much of a look in at that point. Any feedback and/or techy details appreciated.
He who dies with the most toys wins. |
#18 |
Hot Air,
I see no one has answered you, so I will throw in my 2cents, even though I am a relative beginner. Everything I have read, everyone I have talked to says that at 0 stick you should have some negative pitch, -2 to -3 degrees. At 0 pitch, you can still have an attitude that yields some positive pitch, therefore allowing the machine to float too much. Look into some booke/DVDs by Ray Hoestetler, they are very useful. Rick Harms |
#19 |
I agree with rharms. -2 or -3 should be about right. Even at those values if you chop the throttle you won't slam the ground too hard. IMO you should practice autos early on. I started by hovering about two feet up and hitting throttle hold (don't touch the collective). Watch the tail swing as it will when the power goes away. This gives you a feel for how the bird settles without power. When you are comfortable with the settling process start to play with the collective to see how long you can stretch the hover. Move up to three feet and four feet. When you get to the point where your alitude will not allow you to land softly you then go up high and do a real auto.
One thing for sure.... you either land or crash... Or is it crash landing![]() Is this the right way to learn and auto?????? I don't know, but way back when this is what I did. FWIT, My GMP Cobra was very easy to auto. My X-Cell 40 I've NEVER been comfortable with autos. |
#20 | |
This is a really good video for autos. This is how I learnt how to do autos. Thank you bob for all your videos. I refer to them every so often for a refreshing course and motivation. One thing I learnt with a 250, I have to have a bit more negative, so that I have more HS to have tail control. Any tips for inverted autos on a 250? . hehe
