Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 10-11-2010, 08:14 PM   #1
tonycip
Default gyro creaping
Hi I'm having a problem with my gryo its a Jr G500T. On a blade 400. Here’s what its doing the noise is drifting left.
So I put it on the bench to check it out and I observed this after it initializes. It starts to creep right If I move the rudder right it goes left then after I center the rudder it slowly creeps all the way right. Any Ideas what would cause this?
tonycip is offline        Reply With Quote
Old 10-12-2010, 08:28 AM   #2
wanderer56
Did you try lowering your gain just a bit? I assume this is in HH mode? What does it do in RATE mode? If it still does it in RATE mode, you may have a tail servo about to go out on you.
You could also try by-passing the gyro (plug servo directly into rudder ch on rx) and see if it still drifts. That could help you pinpoint gyro from servo.
Trex 500-3226-1600, 14T, Koby 90LV, HS-5245MG, DS655, AR7200BX, DFC
Trex 450 Sport-2221-8, 15T, CC Edge 50 Lite, HS-5065MG, HSG-5084MG, AR7200BX, DFC
DX8
wanderer56 is offline        Reply With Quote
Old 10-12-2010, 08:30 AM   #3
BarracudaHockey
Adjust the sub-trim on the rudder channel until the servo doesn't drift.
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote
Old 10-12-2010, 11:23 AM   #4
tonycip
Thanks sub trim has got me thinking, I did adjust the sub trim to get my servo arm 90deg.
But I did re initialize it, is the sub trim somehow adjusting the gyro? If so what do I center the arm with? I thought all I had to do was get my servo centered with the sub trim and then adjust the linkage back to the tail square and that would solve my slight left drifting. But now it’s worse..
Following this tips for noobies.
http://www.ronlund.com/tr_setup.htm
Old 10-12-2010, 11:26 AM   #5
BarracudaHockey
You have to adjust the sub trim to stop the creep. Only way to adjust the servo center is use a different servo arm. Find a star arm, rotate it 90 degrees at a time, find the one thats centered and cut the rest off. Or use a wheel and drill a hole (thats better anyways because its stiffer)
Andy
AMA 77227
Jacksonville FL
Old 10-12-2010, 11:27 AM   #6
BarracudaHockey
Oh ya, ignore any posts that say not to use sub trim
Andy
AMA 77227
Jacksonville FL
Old 10-12-2010, 12:09 PM   #7
kenh
And... Adjust the pushrod in rate mode (trim and sub trim at zero) so the heli does not yaw when hovering. Then in HH mode adjust the sub trim so the servo does not creep.
kenh is offline        Reply With Quote
Old 10-12-2010, 01:54 PM   #8
BarracudaHockey
Actually, adjust the sub trim first so you don't get any servo drift, or you will never get a stable hover in rate mode no matter what you do with the linkage rod.
Andy
AMA 77227
Jacksonville FL
Old 10-12-2010, 05:08 PM   #9
tonycip
ok thanks I'll go try that now.. 1st sub trim than change arm, and then adjust linkage .
stay tuned!
Old 10-12-2010, 07:43 PM   #10
tonycip
yep that did it.. all better now...thanks Barracuda..
Old 10-13-2010, 07:08 AM   #11
BarracudaHockey
No problem, glad you got it going
Andy
AMA 77227
Jacksonville FL
