Old 02-22-2013, 07:46 PM   #381
Inverse
Default Show Off Your Wiring!
Looks sweet!
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 02-22-2013, 09:13 PM   #382
cipioh
Default Re: Show Off Your Wiring!
Originally Posted by Inverse View Post
Looks sweet!
Thanks!
Tarot 450 Pro V2 Build Thread:
Tarot 500 Build Thread:
color="Blue">Searchable Video Index: http://cpoheli.com/
cipioh is online now        Reply With Quote
Old 02-22-2013, 09:52 PM   #383
cipioh
Oh...I forgot to post this too. I put together a video, as part of my build series, on more detail of how I ran the wires, and what methods I used inside.
Hope this is helpful for folks looking to cram a bunch o wires into a tiny 450. ; )
Old 02-23-2013, 01:22 AM   #384
ForHim
Default For your review.
OK, I'm able to post pics now, woo hoo!!!! I did this build without a single zip tie. If anybody wants I can pull a frame side off and take a pic of the guts.
Nothing rubs or slips, I have about 9 batteries through it already and check it out frequently.
Here you can see I pulled the ESC wire out the back and connect it with an extension to the RX. This lets me use a RX battery for setup and bench testing. No need to have motor wires hanging out.
Thanks Heli Freak!!
ID:	396942   Click image for larger version
ID:	396943   Click image for larger version
ID:	396944   Click image for larger version
ID:	396945   Click image for larger version
ID:	396947   Click image for larger version
ID:	396948   Click image for larger version
ForHim is offline        Reply With Quote
Old 02-23-2013, 03:53 PM   #385
kenkadish
Moved to 450 Pro forum
Blade SR - 837 flights; Blade MCPX - 725 flights
Trex 450 Sport - 585 flights; Trex 450 Pro DFC - 15 flights
Trex 500e - 86 flights; Blade 300x - 162 flights
Learning every day!
kenkadish is offline        Reply With Quote
Old 03-08-2013, 05:39 AM   #386
demacy
Default Ice Breaker
So here's my first kit built non begginer's heli.
KY's CopterX Black Angel FBL
Winter build so plenty of time for aesthetics
As you can see I've got some black powders stuff on my main gear, spares in the mail.
hope ya like it!
demacy is offline        Reply With Quote
Old 03-08-2013, 11:08 AM   #387
rdlohr
Default This Rush 750 was an absolute joy to build!
Left Side
Right Side
VBAR
Flagship Heli
Full build thread here with more pictures and story:
http://www.helifreak.com/showthread.php?t=507842
Rick
Helifreak, the place to be!
Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X
My products, flown by top pilots around the world, like you!
rdlohr is offline        Reply With Quote
Old 03-10-2013, 10:10 PM   #388
racerjeffrc
Default Heres mine
Aha
racerjeffrc is offline        Reply With Quote
Old 03-10-2013, 11:51 PM   #389
nameci
Hey Rick, that's not 450 pic.
Anyways, it looks great. You are twisting my arm for my next purchase.
nameci is offline        Reply With Quote
Old 03-31-2013, 11:17 AM   #390
Blue Blades
Default HK450GT
Here's my brand new HK450GT just finished tonigh!...
ID:	408204   Click image for larger version
ID:	408205   Click image for larger version
ID:	408206   Click image for larger version
Blue Blades is offline        Reply With Quote
Old 03-31-2013, 12:07 PM   #391
Steve Evans
rdlohr,
That's a simple, and really neat helicopter rack. I keep my 500ESP and 450Pro in their carry cases, with the 450SEv2 sat on top of the 450Pro case for a lack of anywhere else to put it. I'm now tempted to screw a batton to the wall and keep all three on display.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 04-03-2013, 11:20 AM   #392
Ohio_Danimal
Has anyone here experimented with using Sugru to run wires on their build?
I have used Sugru (Formerol) for quite a few things, and thought it ideal. It sticks to anything, remains workable for 30 min, and even when fully cured 924 hours) can be easily removed if needed.
No zip ties...no harnesses...everything can be hidden nice and neat.
I'm in the middle of my first 450 build...will post a few pictures once the Sugru hardens.
Here...you can see the three servo's wires...nice and flat against the chassis and pushed down into the Sugru.
Ohio_Danimal is offline        Reply With Quote
Old 04-13-2013, 10:53 PM   #393
cjpainten
cjpainten is online now        Reply With Quote
Old 04-14-2013, 03:59 AM   #394
Steve Evans
No zip ties...
Looks like it would add rather more mass than zip ties, wouldn't be as strong, takes a day to cure vs being instant and is possibly a pain to remove, whereas snip and a zip tie is gone.
Steve
Futaba 8FG 2.4GHz
Old 04-20-2013, 05:04 PM   #395
danhampson
i just use a tiny drop of CA on the the cable, can be removed with minimal force but doesnt go anywhere
danhampson is offline        Reply With Quote
Old 04-23-2013, 11:57 AM   #396
wbiewon
Originally Posted by JDFiend View Post
Wow! I've been to about 8 stores and nobody carries that stuff. Home depot, lowes, best buy, pep boys, oreilly auto, 2 local hobby shops. I guess I will have to order some online.
Thanks for the links.
its called techflex. they make the best sleaving. just google techflex. i but 1/8" from a company called MRO electronics
wbiewon is offline        Reply With Quote
Old 05-08-2013, 09:11 PM   #397
Tatmonster45
Default My wires
Here's my first try at this
Tatmonster45 is offline        Reply With Quote
Old Yesterday, 07:51 PM   #398
junior10
here's my first trex 450 pro dfc build and man does she spool up smooth
junior10 is offline        Reply With Quote
