Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Fusion 50
Outrage Fusion 50 Outrage Fusion 50 Electric Helicopter Factory Support Forum
View Poll Results: Tail Servo Mount Style
Boom Mounted Servo With Brackets 11 19.64%
Frame Mounted With Plastic Tray 45 80.36%
Voters: 56. You may not vote on this poll
Old 10-14-2010, 03:28 PM   #1
Charley Stephens
Default Fusion 50 Tail servo placement
Guys,
I have a decision to make and would like some opinions to this.
For Fusion 50, I have 2 options to mount the Tail servo which would be your choice.
1. Servo mounted on Boom using brackets similar to 550 and many older helicopters
2. Frame Mounted semi-inboard in a Plastic tray. Tail control rod will 1 piece and have a "Z" bend shape to help keep rod inline with boom no set screws or couplings
Here are some pictures please vote
http://helifreak.com/attachment.php?...5&d=1286349026
Charley Stephens
Charley Stephens is offline        Reply With Quote
Old 10-14-2010, 03:38 PM   #2
raptorheli2
i'm not a fan of boom mounted servos. i've lost a couple in crashes through damage and i've lost one completely!
tail boom servos imo should stay confined to the past-there is no need for it with TT helis for me.
cheers
raptorheli2 is offline        Reply With Quote
Old 10-14-2010, 04:18 PM   #3
DRM Black7
Defo frame mounted, buy not to keen on the z wire for the pushrods, what about a carbon rod with a u shaped guide.
Or could the servo sit in the side of the frame, similar to how it sits in a Velo but at the back then use the velo pivot and a short push rod.
Gaui X7 Formula
Trex 450L Dominator
Oxy 3 Lynx pilot. 2nd place Sports class, Helifest 2015
DRM Black7 is offline        Reply With Quote
Old 10-14-2010, 04:23 PM   #4
DominicD
The Capi
Charley perhaps you can give us the cons and pros of both options so we can make a more informed vote.
DominicD is offline        Reply With Quote
Old 10-14-2010, 04:25 PM   #5
DRM Black7
Something like this. Sorry about the crap drawing lol
Gaui X7 Formula
Trex 450L Dominator
Old 10-14-2010, 04:27 PM   #6
DominicD
The Capi
Old 10-14-2010, 04:38 PM   #7
Wurger
Im not a fan of between the frames like the 450 pro did it. The servo's position made it hard to get the rod to be straight buuuuut I am even less of a fan of the servo being on the boom though because I took took out a few servos there... so I voted for in the frame.
I llike DRM's idea using the typical velocity bell-crank but I am sure its too late to do that.
Where I moved.. the only nearby field is electric only so I am pretty enthusiastic for this helicopter.
Wurger is offline        Reply With Quote
Old 10-14-2010, 05:14 PM   #8
MaSt0RaS
In the frames in order to be protected....!!!
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote
Old 10-14-2010, 05:23 PM   #9
Andyzboy
I like the frame mounted setup, less things to pull off when you're replacing a boom and it looks cleaner
Andyzboy is offline        Reply With Quote
Old 10-14-2010, 05:50 PM   #10
OUTRAGE RC
Please have a close look at the Z bend. This is just a prototype one , the new one should look like the drawing.
Steve
ID:	184933   Click image for larger version
OUTRAGE RC is offline        Reply With Quote
Old 10-14-2010, 09:23 PM   #11
Slyster
I voted boom.. but now that I've read the thread I changed my mind. I do like boom though.. so easy to adjust etc. I've never damaged a boom servo.. you just have to position them right.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 10-14-2010, 10:48 PM   #12
Rob43
I voted boom since I've never had servo damage at the boom. Mounted "port side", with proper wiring management helps defend against damage even if the boom is broken at the boom block.
The z-bend can actually be stronger than a simple straight rod, however. It will tend to resonate less at full steam. I wound up adding an additional guide to my 550, as the 8900G was healthy enough to buckle a bit.
As Capi said, if there are some design issues with either, voice them. Not a hot topic for me either way.
= Rb43 =
Rob43 is offline        Reply With Quote
Old 10-14-2010, 11:19 PM   #13
AnTi Taco
Just make it so the builder can choose have the inside the frame mount but also allow for it to be on the boom...kinda like the 450 pro some follow the instructions and mount in frame and some just put it on the boom ..just add a extra tail control rod for a boom mount
Compass 7HV 9180/9188 Vbar
Compass 6HV 9180/9188 Skookum,4025-630KV
Compass 6HV Savox/ 9188, Vbar,
Fusion 50 9080/9088 Beast X
Velocity 50n 9080/9088 VbarSAB Goblin 9180/9188 Kontronik helijive Coming soon
AnTi Taco is offline        Reply With Quote
Old 10-15-2010, 12:10 AM   #14
kazager
That's an interesting thought. I wonder if it's feasible.
I like that it's direct. I ultimately prefer the side frame mounted with the servo wheel between the frames like the e-Aurora and Pantera 50, others too I'm sure. With inflation, my 2 cents aint worth what it used to be. I'll be fine with it either way, but I voted for frame mount not boom mount.
kazager is offline        Reply With Quote
Old 10-15-2010, 12:57 AM   #15
guyro
Hi Charley,
Why not have the 2 options in side the kit and let each pilot build what ever he prefers?
My 2 cents from the other side of the world....
Guy
guyro is offline        Reply With Quote
Old 10-15-2010, 01:39 AM   #16
silverbullet
Thumbs up
1.Very nice work again!!
2.If there are a difrent Pushrood awaible (shorter one) plus the 2 parts for boom-mounting, customers could
do however they like ,and it would be the ultimate solution,,
3.I personally vote for the inside the Frame Way,,, looks much nicer,,
silverbullet is offline        Reply With Quote
Old 10-15-2010, 06:36 AM   #17
raptorheli2
fyi the servo i lost and i mean it was completely gone was on the "good" side away from rotation. i concluded that by fact only had 3 broken wires left that had obviously been pulled. i have broken 2 and lost 1 on the "good" side so i avoid them now completely. i know some have more luck but i got sick of buying tail servos.
cheers
Old 10-15-2010, 07:19 AM   #18
Foxden
I like the inside the frame location myself, "Z bend" should not be a problem, we've had them on the Raptor 60 for ever and it has never been a problem
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote
Old 10-15-2010, 08:35 AM   #19
Charley Stephens
Thanks Guys keep the votes coming.
I needed to know what you guys would like to see.
the 2 options is an Idea but time will tell
Thanks Guys!
Charley Stephens
Old 10-15-2010, 10:16 AM   #20
OUTRAGE RC
Thanks for voting you guys. Please note for this design we need to have Zbend in the option of servos on frames. I know that a lot of people prefer servos on frame, me too. The only thing you should also consider is the Zbend shape. Will it bother you? Will you think it's not looking good?
We cannot have both options in the kit. Only one.
Steve
