| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Still suffering from CWS (Cronic Wag Syndrome)
I've been focusing so much on making sure my tail isn't binding, that I didn't pay close attention to how much slop I had and if that was the culprit of my waggy tail... As you can see in this video, I don't have much play in the tail grips, but there is a fair amount of play if I pitch (or twist) the blades... Is this normal? If not, how do I eliminate it? It seems to be in the slider and connecting linkages... |
Steve, that pretty much normal for the 250. I have the "slop" and the stock tail works fine. Remember that you are judging things in the static state, the dynamic state is much different. The forces are pretty high when spinning @ HS 4600 rpm the tail is around 19k rpm putting about 60lbs of rotational force on the hub to grip screw heads and it takes about 3-4lbs of lateral force to make the grips rock on the head of the screw "slop" Just something to consider.
Got Freak? Paul Sr. "There is not much difference between pipe and tubing" BEAM E4 ~ds760+S9257~HS-5065~2221-8~ CC45~Eagletree+GPS 250SE~CC25+Scorpion 3900~HS-65HB~Quark~DS290~All metal ugrades~KDE |
Steve,
I just check my 250se and the blades move about the same as yours do when twisted. There is one difference I see from your video, it appears that your tail shaft is sliding about 3-4x as much side to side as mine does. My tail shaft only moves a few thousands of an inch sideways inside the housing. Maybe try shimming between the belt pulley and bearing on one or both sides. This movement translates into a pitch change and dead zone. Good Luck, Don |
Yeh, I noticed that little bit of play of the tail shaft inside of the housing... I just checked it very closely, and the amount of play is the thickness of a piece of paper. If I work hard enough, I can just about slip a piece of paper in between the belt pully and the bearing... the video makes it look like there is much more play then there actually is... I would say that mine is a few thousands of an inch just like yours.
Hi have you seen this?
http://www.helifreak.com/showpost.ph...&postcount=111 So far I have zero tail wag....... then again, I've not had time to finish mine, so fingers crossed when I do |
#6 |
i got a set of aluminum pitch slider links from helidirect and that seemed to cut a lot of the slop from my se tail...
Thank god i have snowboarding to keep me occupied when its too cold to fly! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 | |
Vergnugenstabi [adj.]pleasure/stability The enjoyment and feeling you get when flying a vbar. [farg-new-gen-stab-e] CF Logo 600SE.. Robert A. Team HAIYIN |
#8 |
Interesting posts guys!
That is a great link Toys2Cars... actually it is a great thread that I will read through in detail! I might have to give a set of those aluminum pitch slider links a try with my next order of parts, RyuuChi. Bob - I'm a bit confused... I only have three screws on my tail case... are you talking about the two black plates that hold the bearings for the Metal Tail Rotor Shaft? |
#9 |
YUP
#10 |
ohh man steve, that's slop. on the blade grip, that is slop. I adjusted my blade grip so it doesn't have that play (this is on my hk250 plastic), by sanding down the hub. As for my tarot(which is metal), I took out the blades grip screws and rethreadlocked them, and tightened the screw so there is minimal movement, but not much binding, there is a little, but I can live with that(better with a slight bind than slop). As for the movement on the slider, I had that too, same amount of movement. I put a dab of CA on the ball holder to make it tighter(this I find wears out over time, so I check it (this requires TLC, as you can't put too much CA or there is total bind, I only put just enough CA, one coat until there is no play, I allow the CA to completely dry out, then I put a drop of oil before reinserting the ball back in, once this is done by hand i move the slider about 20 times and it gets a little bit loose, I apply another drop of oil while the ball is still in the holder and repeat the tail slider movement). I also put an extra washer in the gear to stop it from moving(So that gear movement in the gearbox is very minimal,but yours is a different gear to mine, so you would have to adjust differently). I hope this helps. good luck dude
Also for the tail blades holder screw, i've replaced them with nuts and bolts( I had to make the holes bigger), and threadlocked them. I check this everytime because of my High HS, things get loose over time. So I adjust it accordingly Last edited by pitchp; 10-20-2010 at 05:14 AM.. |
#11 | |
.. another point i can tell you that will affect the overall setup is the belt .. those kevlar belts are stiff and i would strive to get a belt tension as loose as possible .. not sloppy but definitely not tight .. .. also to keep adding to this post heheh, what i found on the 250 i fly almost daily, is that eliminating all slop ( which i tried to do) actually results in a situation where i have to run less gain and experience even MORE of a problem with wag, especially flying in a stiff wind .. just a thought .. i wouldnt waste time trying to tighten the bejeebus out of the tail action .. your linkage and control arm looks tight and thats the main worry on slop .. |
#12 | |
Every time I crash I wonder, why didnt I get into RC tanks. |
