| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#61 |
I sincerely want to thank you for your service. My father is a vetran of three foreign wars. I would likely have made it there myself if I would have passed the physical. My ASVAB scores were in the 95th percentile.
Hey, it takes about three weeks to get Zippys. So you'll want to order them soon if you go that route. I am happy to answer any questions that might come up. If I don't know the answer, I'll know who to ask. God speed on your safe trip home.
vbar T700E v2 DFC head, Pyro 700-45L, Jive 120HV, BLS451/BLS251, Edge 693/115 vbar CF Protos Scorp 3026-880kv, Ice lite 75, 9650/BLS251, SAB 430/KBDD 82 |
#62 |
Thanks Tera I appreaceate that seems alot of folks have forgoten you dont have to support the politics to support and remember the soldiers.....most arnt here outa choice....as far as questions go im pretty new to this sport im sure alot more questions will be forth coming
#63 |
I just got the notice from hobby city these are now available they now have 284 left just bought 3 myself
Z50006S-25 ZIPPY Flightmax 5000mAh 6S1P 25C |
#64 |
Good! Just remember to ease them in. Hoover fror 3 or 4 minutes for the first 3 or 4 cycles per battery using only about 50% or 2500mAH. Charge them. Divide the number of mAH put back into the battery by the number of minutes used and always make sure you keep under 80% of the 5000mAH rating. In fact, you probably don't want to exceed 70%. They'll last longer that way. It took a little longer to get my Zippys to balance for the first several cycles but, that is important also.
One thing about Zippys, they don't tend to store real well for long periods. So, you're probably just going to have to fly the crap out of them.
#65 |
ok ill try that....I spend more time working on my hover orientation then anything else anyway im always after that elusive control touch....btw do any of you know any New York mikado pilots...Im looking for someone who knows their stuff to show me the ropes....I made the mistake of buying an rtf T-Rex with tx bad move on my part didnt learn anything other then flying....
#66 |
V-BAR Guru
Thought I gonna post a graph (got 50 of them or so)
Insanely powerful setup, #1 choice here right now, this or -630 motor. Date: 2009 Logo 600 3D - VBAR - HK4035-560, 18T mod 0.7 Setup style: 3D / Sport / Scale ? FAI: 3D, lots of stickbanging Ambient Temperature: 12C Motor and Pinion: HK4035-560, 18T mod 0.7 ESC "Brand and size": Jive at 68%, endpoints adjusted Lipo "Brand and Size": DesirePower 10s1p 4500 Length of flight: See graph Headspeed: See Graph Motor Temp "average or on landing": 55C ESC Temp "average" or on landing": warm but not hot, using heatsink. Lipo Temp "average or on landing": Barely warm MAH put back into pack after flight: See graph.
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#67 |
Here's my setup. 4th flight on this bird and I have a feeling it's just getting warmed up.
Logo 600 3D Vbar Xera 4030 2.5y 560kv 18 tooth mod 0.7 Jive 80HV 8717 BLS251 AR7000 Radix 600mm Radix 95mm Outrage 10S 4200 AUW 7.98 lbs 3.62kg 2350 rpm @ 75% 2200 rpm @ 65% 2100 rpm @ 58% 2000 rpm @ 50% Spektrum endpoints at 83/83 which I believe is calibrated for the Jive. Ambient temp was 75 degrees Max in flight temp on motor was 104 degrees and 115 was the highest after landing ESC temp on the flight 4 was 95 degrees after landing Pack temp was 85 degrees
Mikado Model Helicopters Edge Blades |
#68 |
Hello,
Here is a graph of a typical flight with the above heli. I've had about 15 flights with it so far, and am loving it! Setup is as follows: Hacker 1350kV motor and 70A ESC that comes in the package. Futaba 9650s cyclic and BLS251 tail WR 10A Super Mini BEC @ 6V Zippy H 6S 3300mAh batteries Hobby City el cheapo FG blades for now, Mikado tail blades 18T pinion at 77% throttle governed (despite being at 77%, the throttle is as its maximum output, so I plan to turn the governor off once I can figure out how to enter setup mode) AUW ready to fly is 1950g, or 1450g basic weight, heavier than I was expecting. Currently I'm running 2600 rpm for 5 mins and putting back no more than 2100mAh, so I could probably get away with another minute, but I'm going to continue running for 5 minutes and increase pack life. I'm not measuring temps, but all electrics are running very cool so I feel this is an efficient setup. I am extremely happy with the results this heli has given so far. I'd describe my flying as "intermediate," so prefer flight time to performance, but I feel that 2600 rpm is giving pretty good performance all the same. The second image is a screen shot from an application called "Hobby Central" by Martin at archeli. It is handy because it shows your min, average and max values for a variety of parameters at a glance. It also includes things like C rating and motor efficiency. Did I say I love this heli! |
#69 |
I have a very common/standard setup on my Logo500 Flybar
This setup is safe on heat and current yet has good power Main blades: 550mm RotorTech Tail blades: 92mm RotorTech Motor: Scorpion 4020-1100kv Gearing: 153T Herringbone mod 0.7 with 15T pinion Battery: Outrage XP25 6S 5000mah ESC: Align 100amp Servos: BLS451 Gyro: Spartan DS760 into S9256 Model servos using ~80mah per flight! Regulator: Align 6amp (power from 2S TP2000 pack) The data says it all Temps: A=Motor B B=Battery C=ESC ![]()
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4 Gryphon field rep |
#70 |
Date: 6-30-09
Logo400~ 9650 (mks gears), V-bar, 9256, Maniac 427's Setup style: 3D Ambient Temperature: 90 F Motor and Pinion: Scorpion -1400 w/ 19t pinion ESC: Phoenix125 Lipo: ThunderPower Pro Power 30C 6S 3300's Length of flight: 4:30 Headspeed: ~2700 rpm Motor Temp: Hot ESC Temp: Mildly warm Lipo Temp: warm MAH put back into pack after flight: ~2550Mah For what it's worth, the rpm sensor on my ET is not really working properly. Has an odd resonance and is recording a bit less than actual. Also, this is a very fast setup; not for the lighthearted. ![]()
Plank flying... so easy, a caveman can do it. |
#71 |
Model: Logo 500 vbar
Gyro: Futaba BLS251 Servos: Futaba BLS451 Rx: AR7100 Tail blades: plastic with the kit Main blades: Carbon generics 550mm Pitch: +/- 13 degrees Setup style: medium / hard 3D RTF weight: just over 3kg? Ambient Temperature: 55 F Motor and Pinion: scorpion 1100kv on 14T mod 0.7 ESC: Jive 100LV Curve: flat 75% BEC: Jive Lipo "Brand and Size": hobbyking Turnigy 5000mah 6s Length of flight: 4:30 (auto-trim hover with a bit of forward flight) Headspeed: don't know. Maybe 2000rpm Motor Temp "average or on landing": felt like >110°F ESC Temp "average" or on landing": felt like ~95 F Lipo Temp "average or on landing": felt cold MAH put back into pack after flight: ~2000mAh ! I suppose I could do 8 minutes sports flight and be safe on the battery. |
#72 |
Hi all
I dont supose anyone out there has any power setup info for a Logo 20. Mine "had" a Tango 45-08, Beat 50-8-30 ESC and used either 20 or 24 NiMh cells, depending on which packs i used....it also runs 96 and 9 teeth with 620mm blades. Anyway, the 45-08 seized one day, and i sent it back to Kontronik....they told me it was beyond repair, and i cant really afford the 200 bucks for a new 45-08 at the moment. Any ideas which motor i could directly replace it with.....or should i just bite the bullet and replace the motor, esc and batts with a newer LiPo setup.....If so what.... It would need to be something i could transfer to a Logo 500 or 600 at a later date.... I would really prefer the cheaper option at the moment.....would an Align RCM-BL600L or 650L do as a straight cheap option etc ? cheers Ian |
#73 |
wolfman, to my recollection the 45-8 was abit over 700kv, so that's abit on the higher kv range... I may have a 45-8 around I will check..
#74 |
Hi Shawn, that would be great if you had one and wanted to sell it.....cheers Ian
#75 |
Ian sent you pm, I have one if you want to use it np.
#76 |
Whoops - posted in error
#77 |
Hi Shawn
replird to your PM, but it says your inbox is full....you might not get it till you delete a few old messages etc.....i think thats what it meant. anyway, heres a c,n,paste of what i replied to you. cheers Ian Hi Shawn, That would be extremelly generous of you, and would save me a whole heap of problems also.....Although i really dont mind paying you something for it, and also i would cover the postage as i am in Scotland UK. my zip code is KA9 2PU. if you could get a postage quote then i can pay you. How can i pay you ? would you accept a payment from paypal, obviously i would pay the paypal fee also ? that is what we use in the UK here an awful lot, or do you have any other money transfer type that you prefer ? I am going to be away at a car race event for the next couple of days, but if i can log on i will, or else i will be back on sunday evening. thanks again Ian |
#78 |
Date: 1/02/2010
Helicopter & particulars of setup "servos,gyro etc": Model: Logo 10 3D Gyro: GY401/S9254 Servos:JR 3421 A++++ Digital Regular tail blades and regular 500mm mains Setup style: Beginner Motor and Pinion: NEU 14 tooth i think Madusa BEC ESC "Brand and size": Casle Creations 45amp HV Lipo "Brand and Size": Enerland 6S1P 5100ma but Hyperion is the best Length of flight: Up to 10 min Headspeed: 1810 Motor Temp "average or on landing": Slightly warm ESC Temp "average" or on landing": Does not get warm Lipo Temp "average or on landing": Barely warm MAH put back into pack after flight: 3785mAh Radio: Futaba T12ZH Heli command rigid Aluminum motor plate I suggest the JR servo horn;s because they break before servo does I use shorter flybars 300mm 360mm I put two airplane wheel collars out on flybar and use the heavy paddles
Logo 10 Futaba T12ZZH 410Gyro JR servos NEU motor Casle creations speed controls. Last edited by gtxkid; 01-02-2010 at 10:36 PM.. Reason: Add info |
#79 |
My new toy, first real flights this past Sunday:
1/26/10 Logo 600 3D FBL VBar 4.0, Spektrum satellites BLS 451 tail BLS 251 cyclic Hacker A50 14L Mod 1, 13T pinion Hacker X80 Opto Pro 3D ESC WR Hercules Super BEC, 6 volts Hyperion G3 VX 5S 4200mah X 2 Edge mains/tails, 95 (have a QuikUK tail set, haven't put them on yet) only upgrade was a metal boom brace bracket (never liked the plastic ones and I don't use a horizontal fin) Aggressive 3D VBar setup Governed, 80% Idle 2, HS 2250rpm So far, batteries and components mildly warm after 5:30 flying time, moderate 3D, 70% discharged. Have been "conditioning" batteries. Any need for that with these newer high dschg batts? Awesome flight performance.
Robbie Last edited by rchaas; 01-30-2010 at 12:24 PM.. |
#80 |
Badass machine!
Some say no on the conditioning but I definately do it with mine. And I don't care what make either. I am currently using Hyperion G3 35c, TP ProPower 45c and Outrage XP25c lipos but I've also used Zippy's and I treat them the same way. A couple of my 10s Outrage XP25 4200's have well over a hundred cycles and they're still going strong. I believe part of the credit belongs to good maintenence which includes conditioning. I start by discharging to 50% in a hover. I add a minute each cycle until I reach 75%, usually three more cycles. Then I back the timer down 30 seconds, raise the headspeed a touch and do some moderate sport flying for a couple cycles. I don't push my lipos "hard" until after the first ten cycles. What I've noticed is that the cells will progressively pull into a more consistent balance with each other for the first few cycles. After that you're golden. I also storage charge my lipos if I think they're going to sit for more than a couple days. After a month or so of storage I'll cycle them (charge/discharge) on the chargers. And I don't let them get or stay too far from 75F if it can be avoided.
