Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > 330X
330X Discussion and support of the Gaui Hurricane 330X QuadCopter
Old 10-21-2010, 12:57 AM   #1
Freddd
Default GU-344
Is the light on the GU-344 suppose to flicker from red to green when the green wire is not plug in to the Rx? Do I have a bad GU-344?
Freddd is offline        Reply With Quote
Old 10-22-2010, 05:39 PM   #2
Freddd
To answer my own question, I found that the green wire has to be plugged in to something. I plugged it in to port 5 on the GU-344 and it works fine.
Old 10-23-2010, 05:57 AM   #3
eDeK
It doesn't have to be plugged "in something"
You can plug it only if you want to set the gain via your transmiter. IMO,the better way ,a bit smoother it to set it manually with the potentiometer on the module.
eDeK is offline        Reply With Quote
Old 10-23-2010, 10:01 AM   #4
Freddd
That's not how it was with my gyro. If I let the plug "float" then the mode would flicker between hov and cruz. I was only able to make it work with the green line plugged in to one of the empty ports on the gyro. I agree that having the green line plugged in to the RX is a better way to go for me. It may just be my gyro but I hope this may help someone else in the future.
Old 10-23-2010, 10:05 AM   #5
eDeK
BTW,the green plug has to be connected to GAIN channel on your receiver,not in the 344.
Old 10-23-2010, 12:02 PM   #6
Freddd
Yes, I've been doing RC for 20 years. The green wire, when not plugged in to the RX, must have a pull down resister or the port will float. For some reason its not working on mine. By plugging it into the 344 I have pulled it down and it is not floating anymore. Like I said, I have it plugged into the gain on my RX and it works fine but I not like having equipment that does not work as advertised.
