| Kyosho Kyosho Caliber, Kyosho Helicopters |
Almost no posts about the Caliber 5 here? Does anyone have a problem with it or did they design a perfect heli?
Team Thunder Tiger Europe 4RC.nl, Edge rotorblades, Scorpion systems To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Yes i have one big prroblem ! It's rainning and it's cold out, no flying for me.
. But i have had one problem, the clunk lines in both tanks were crapp, so replaced them with some black lines and they were even worse. But it's been flying just fine. This is my first glow powered heli and i am only on ff #12 I hoverd for a gallon and a half. I would say so far it is the perfect heli ! :?:
If its not broke your not driving it hard enough ! Kyosho caliber 5 TT raptor 30 v2 mx400 pro (Up and flying now) |
Problems, let me see. Oh yes, the fuel lines were getting bad, so I am glad that I checked them and changed them out. Also, the spindle came out of the head. See my other post. That was exciting. However, most of my other problems have been learning problems. Not having had a helicopter before, I do not know what is right and what is wrong with the Cal5. All I know is that they are supposed to hover, go forwards and back and so on. Mine seems to do that, so I assume all is well. With the heli anyways, not so much with the pilot. I am installing my new blade grips, spindle, thrust bearings and so on this Sunday at work since I have duty. ANy advice on that would be nice.
I see that the Raptor, while a good bird with lots of part supports seems to require upgrades straigth out of the box. Is that correct or are people just going for the bling factor? Ans as to the bling factor, has anyone upgrades their Cal5 with the Version M head? I see that it is all metal and has the flybars over the main blades, similar to the Raptor. Does that make any difference or is it just manufacturer preference?
Look Ma! I can hover! |
When you have finished flying for the day, refuel, disconnect muffler pressure line, defuel. This expells exhaust gasses from the tank. Exhaust gasses are corrosive and eat your clunk lines.
I have ad my Caliber 5 for almost 4 months now. and I have come across very few problems associated with the helicopter itself. I did find that the if the fan is not properly tightened when assembled it will fly off when you start it. red or blue lock tight is a must for this and a engine crank shaft piston lock tool.
I had a hell of a time getting my blades to track perfectly the linkage setup that is used makes it difficult to make small adjustments, but this can be said for other helicopters as well, when we are talking about linkage you have to remember you cant make Half turns safely with linkage. my tracking is good now, not perfect, but not causing any vibe problems. Overall, I cant complain about my C5, I really enjoy it. I did change to Carbon fiber stabilizers, horizontal and vertical. Its light with good amount of power from the hyper O.S. 50. |
#6 |
Since the last rebuild I removed the horizontal stabilizer and I'm thinking about modifying the vertical.
